Press and hold the POWER and the HOME button until you see the Apple logo on the screen.
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE or contact me personally at this email: [email protected] or add me on Skype: ebayseller.ca
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
there is 3 possible problems i think here, one the conection to computer is faulty, 2 the battery it selfs is busted wont hold its charge, 3 there is a switch that decides charge and no charge on main board and its faulty, if its number 3 its a big problem very hard to replace if you have warenteee that is your safest bet or search ebay for a secound hand board, 2 try another batter to see if it holds the charge, 1 wiggle the conection to see if you see any charge goign to batter at any one time, is all i can say to help you here. hope this helps
while you are holding the volume plus button down,plug your player in your puter and keep holding the button until it goes into the recovery mode.it worked for me.
I have a Medion laptop as well.....unfortunately, this is just a cheap battery. Mine can be fully charged, but will only last 30 minutes even if it's just sitting on the desktop. You can try changing your "performance" settings (hold your cursor over the battery icon in the taskbar, it should give you an option change "power plan"). Choose a lower power-consuming power plan (note, lower-power consuming plans won't let games, etc run right). But, ultimately I think you'll find it's just a bad battery that won't hold a full charge anymore.
