Question about Heartland Refrigerators
Why does door squeak when opening or closing?
Posted by Cora goettl on
Tom Chichester
    Top Expert:
  • Heartland Master
  • 55,379 Answers
The door could be slightly misaligned, putting an uneven load on the hinge(s) as the door is opened or closed.
Posted on Aug 18, 2015
Jerry Kramer
  • Heartland Master
  • 3,904 Answers
It is either the metal hinge points which can be silicone lubed or it is your seal rubbing on something which can be cleaned and should go away.
Squeaky seal on lg french door
Just get some wd40 and spray the inches, as they have gone dry
Feb 16, 2014 | LG LFX25976ST 24.7 Cu.Ft. French Door...
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
Door Make Noise When Open and Closing.
If it is a squeak, you can lubricate the door hinges. If it is some other noise you will need to describe it.
Aug 18, 2011 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Dryer GLER642AS3 loud squeaking. Squeaking sound probably coming from drum rotation bearing. Is there an easy way to get in to oil that location to stop squeaking noise? Thanks!
yes but you will have to take the front of the dryer apart and pull out the drum/tub. to do this you must open the dryer door and look up for two screws, remove them. next close the door and using a flat head screw driver, pop the dryer lid/top up (be careful not to bend apart the two green snaps that are holding it tight on each side). now using a phillip head screwdriver in each inside corner you need to unscrew the screw. now lift up and out slowly to remove the front of the dryer ( unplug the dryer door wires before removing front completely). now you must pull the tub straight out (you might need to reach in and take the belt loose first). Now you are where you need to be.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jul 16, 2011 | Dryers
Is there any grease points for the door hinges? The door squeaks every time we open.
Hello. Get a can of a penetrating lubricant called WD-40 with a tiny tube applicator included. Open the door and you will see part of each hinge where the door meets the appliance case. Spray the penetrating lube on the exposed part of the hinge and then open and close the door a few times. Repeat as necessary. J.
Jul 01, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Liftmaster garage door squeaks very loudly, I have luped all parts on the door but sound is coming from motor?
This is usually caused by a bad bearing on the shaft of the Gear and Sprocket Assembly. When it wears enough it will also let the chain come off the sprocket. If you look at the sprocket closely you can usually see that the shaft is leaning toward the door.
Apr 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Back door makes terrible squeaking noise when
When you open your door you will see a flat bar that slides into the door while opening and closing. It is located between the two door hinges. There is a rubber on the door where the flat bar slides in and out, remove that rubber and you will see little rollers in the door, those rollers need to be oiled, preferably with engine oil. Oil the rollers and work the doors back and forth, the noise should abate.
Feb 21, 2010 | 2005 GMC Envoy
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
Garage door squeak when closing
I had a similar problem and tried simlar fixes. Spraying the chain, the rollers, the track with silicon based lubricant did not good for my problem. My wife then listened carefully from where the squeak was coming. It was coming from the hinged in the actual door, the hinge like parts that allow the door to roll up. After we sprayed all of them, the sound just went back to the normal electrical / mechanical sound of the door opening and closing. I am sure our neighbors are happy too after 6 months of (very) early openings. Hope this helps.
Mar 21, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Squeaky door
wd will not work order and replace the door link assembly installe all parts in the bag, youll be fine easy repair part number 8194001
Nov 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Refrigerators Logo
114 people viewed this question
Top Heartland Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Heartland Refrigerator Expert? Answer questions, earn points and help others
