I have the main office line at my desk, it's extension is 500, I also have another line that is supposed to be my direct dial, it is extension 557. The 557 line used to be in another office, but there is no longer a receiver in that office and I need to be able to answer both lines and receive the voicemails from both phone numbers. Is there a way I can set up the other line to transfer any voicemails left to the main line?
SOURCE: Trying to Transfer a Line to Ring at anothers desk after 4 rings.
When my boss is on the phone she wants all incoming calls to bounce to my line. or ring so she knows an incoming call is coming. what can we do?
SOURCE: Phantom Voicemail Recording
Most voice mail systems have 3 levels of greeting, No Answer, Busy and Night. Did your new user change all 3?
Carl
SOURCE: MY PHONE SAYS "MAKE BUSY" ON MY LINE. IT WILL NOT FWD TO VM/ ONLY BUSY!!
You have to ask your phone administrator to add a "make busy" button to the phone.
SOURCE: mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
SOURCE: Mitel 5220 IP phone won't ring when the main line is ringing
It's even simpler than previously solved; The system administrator can correct this for you in a simple programming change. In the form Multiline set key assignment change the ring type from "No Ring" to "Ring" that's it, done! (I hope you enjoy the digs).
