Question about Sony KDL46EX400 46 in. HD-Ready TV
We unplugged our Sony KDL40XBR40 TV when we went away on vacation. When we came home and plugged it in the TV has no power lights, picture or video. Any suggestions?
No power lights, picture or video when we plugged the TV back in. Have checked the wall plug and the cord - both are good
Posted by chris on
Chris Hunt
    Genius:
  • Sony Master
  • 1,342 Answers
Double check the outlet has power and the plug at the TV is fully seated in.
Posted on Oct 20, 2015
5 Related Answers
Anonymous
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
Anonymous
  • 3 Answers
SOURCE: TV Had Burning Smell and Now Won't Power On
It is a real possibility that the power board has failed.
It is fairly easy and safe to remove it and inspect it and the burnt component will be easy to find.
Make sure you place the TV on a flat surface screen down where it is well supported. Do not put anything on the table under the set if there is a chance it will come in contact with the screen. Allowing the weight of the set to rest directly on the screen presents a real risk that the screen will break. Lying flat on a table, the set will rest on the frame around the screen which should be safe.
Do not apply power to the set with the back off as there is a risk of electrocution.
The board is available as a module and can be found on eBay occasionally. The part number is 1-789-496-11 and it will cost between $250 and $300 new.
I suggest you turn the repair over to a qualified service professional for the best outcome. Attempt any repairs at your own risk of creating further damage or replacing the wrong parts. The board failed for a reason. The core cause may not be the power board.
Posted on Feb 13, 2009
ABRsvcs
  • 4234 Answers
SOURCE: Sony Bravia- ghost images and more
Since this set is still under warranty, DO NOT open it up at all. That will void the warranty. Your best bet is to report the problem and request service. Request that this service be scheduled for a few weeks out and try to see if there is a pattern to when it occurs. For example, does the problem seem to occur most often after the set is on for a while? Any information that you can provide to narrow down the conditions when the problem occurs will be helpful. Please report this as an intermittant problem. Even if nothing is intially found, if the problem becomes more regulatr after the warranty period has expired, it should still be covered.
Keep us posted,
Dan
Posted on Feb 16, 2009
Anonymous
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
SOURCE: My Sony Bravia KDL-40S2000 keeps powering off by
Problem may be the power supply,check in it thoroughly and find the falty components.Remove the faulty one and replace new one.
Such as components may be diod,capacitor,power booster.If you are able to do your self other wise take it to the workshop.
Posted on Dec 31, 2009
My 32HLX95 won't turn on. Went on vacation, TV
Unplug,replug an hour later see what happen.Power Supply board might need to replaced.
Feb 24, 2010 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
Lg 42'' plasma 720p no picture
This is not good. Was your tv unplugged or just power button off when you left for vacation. PlasmaTvs are highly susceptible to damage from power surges caused by lighting. Leave unplugged for at least five minutes then plug back in and see if this helps.
Aug 15, 2009 | LG 42PQ30 42 in. Plasma TV
Unplugged unit
when it is powered off hold the power button on the console for about 15 seconds, that resets the video settings.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
No picture displayed on screen
OK, I am assuming you are using the same TV, PS3, cables etc that you were using before you went on vacation. Turn off the PS3...we are going to reset the video display. make sure everything is connected properly before we start. now here we "kinda" gonna turn it on, except you will hold your finger on the touch sensative power button until it beeps several times in a row with about a half second between beeps. It should reset the PS3 and the resolution.
If you get nothing on the screen after trying this several times, you should gather up 150 bucks and call sony for hardware repair.
May 04, 2009 | Sony Playstation 3 (PS3) Console
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Mitsubitshi wd 52725
Good Day;
From you said you should call a Factory Authorized Service Center, toooo many problems with TV for non-tech person.
Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KDL46EX400 46 in. HD-Ready TV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
