Question about Kohler Electrical Supplies
I have a Kohler 25KW industrial generator showing 'auxillary fault' that will not run.
Spec code GM19369-GA3. Model #20REOZJB. It's showing a code 'auxillary fault', and will not stay running more than a few seconds each time I try to start it.There is a triple-gang circuit breaker mounted on the side of the INNER generator housing - each breaker is rated 3.5 - I'm guessing these are for the exciter. Anyway, I found that if I shut this 3 gang-breaker OFF, the engine starts and runs normally, but as soon as I flip this triple gang-breaker ON, the engine shuts down in 2 - 4 seconds, and the Auxillary Fault light comes on. [My controller has 16 lights] What to check?
Posted by David Leland on
5 Related Answers
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
Anonymous
SOURCE: Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Posted on May 06, 2010
consaka
Bryan Fullerton
  • 661 Answers
SOURCE: Kohler Model 12RES LP gas generator starts
Sounds like a short in one of the windings to me. Can you verify that the engine rpm is not exceeding specs? If you can modify the engine speed Id say slow it down and see what the voltage read is.
Posted on Jul 22, 2010
ROMOAS
Robert
  • 97 Answers
SOURCE: I have an 18kw kohler
change the temp sensor and re test the gen set these have a bord that senses if theirs a issue with the engine and will cut the bower to the get head so theirs no load on some mod's then when the temp reaches a higher point they shut down. re-post is this does not fix the issue i will review the books on the unit.
hope this helps
Posted on Sep 01, 2010
Tim Venetis
  • 260 Answers
SOURCE: I have a model #
Make sure oil level is up to par. When it shuts down take the wire off the low oil switch and see if it runs.
Posted on Mar 22, 2011
Testimonial: "very good, quick responce"
Whirlpool cabrio model wtw7600xwo runs for a few seconds then shows fault code f
Could be a defective fill valve. The level sensor could be at fault, also.
Dec 27, 2016 | Whirlpool Washing Machines
Why does my 2004 pontiac boneville start up then shut off again within a few seconds?
most people who do not do the first step generally go crazy chasing the problem
the first step is to have the fault codes read as they are there as a diagnostic tool to stop people from going crazy
Apr 12, 2016 | 2004 Pontiac Bonneville
HOW DO I FIX MY SAMSUNG FLAT PANEL TV MODEL # LN52A650A1F IT WONT COME ON BUT THE RED LIGHT WILL FLASH AND IT WILL DING EVERY FEW SECONDS .
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 04, 2015 | Samsung Televison & Video
Stove clok is not showing time
try pressing the clock button after setting the clock .^-^
Mar 09, 2015 | Kenmore Kitchen Ranges
Machine powers up,,,than the whole machines powers down
Let's see if we can get it into diagnostic mode and check for any fault codes. Make sure the dryer is in standby mode, plugged in with all the indicators off. Select any button except the PAUSE/CANCEL button. PRESS/HOLD 3 SECONDS > RELEASE FOR 3 SECONDS > PRESS/HOLD 3 SECONDS > RELEASE FOR 3 SECONDS > PRESS/HOLD 3 SECONDS. If test mode was entered successfully all indicators will illuminate for 5 seconds with 88 showing in the two digit display. If there are no saved or active fault codes all indicators will momentarily turn off then stay on with 88 in the display. If there are any fault codes, the most recent one will alternately show F- and "XX " where XX is the fault code. and all the cycle indicators will flash. If you can't enter the test mode try a different button. Lets start there.
Nov 17, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
Robinair 34700 recovery problem
It sound like one of the pressure trunsducer is not working or disconnected from the manifold assy.or from ISV tank.Please check Low,High and ISV tank pressure transducer
Jul 08, 2010 | Robinair Cool Tech 34700Z Recovery,...
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Electrical Supplies Logo
75 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
Tim Venetis
Marvin
Marvin
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
