Question about RCA Televison & Video
Hi I have a RCA Model L32HD31YX12 tv and cannot find the code to set up on a universal remote.
Went to RCA site and unable to locate a code to set up. Thanks in advance. Really appreciate all the help I can get.
Posted by Mary on
FRED ALBRIGHT
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
You might try this, worked for my Comcast remotes:
Code for Comcast Remote Control is 13183
Code for Voice Control Remote Control is 12292, however when you go thru the automated process of programming your TV you need to select TCL as your TV brand. Do not select RCA for Voice Control Remotes.
Posted on Oct 03, 2016
5 Related Answers
Anonymous
SOURCE: codes
i need the code # for my RCA DIRE.TV #RCR160SBM1
Posted on Mar 25, 2008
Anonymous
SOURCE: Comcast On Demand Universal Remote Control
try code 10000
Posted on Oct 03, 2008
Anonymous
  • 8 Answers
SOURCE: Promac Tv
Try diplodocs.com. Good luck!
Posted on Feb 11, 2009
Anonymous
SOURCE: universal rca remote rcr312w codes for sylvania tv
the code for sylvania rcr312w is 1192
Posted on Apr 20, 2009
Anonymous
SOURCE: tv codes for a rca universal remote controller
need remote control codes for a toshiba 32A35 with a rca remote
Posted on Jun 24, 2009
HI, I have a RCA Model: L32HD31YX12 TV and when i plug the power and cable into it all I get is a black screen. The green light at the bottom of the TV is on but I'm not sure what to do. Also I do not have...
I have an RCA LCD TV Model#:L32hd31yx12. I have an issue with the settings staying in place when I shut it off then turn it back on I have to reset everything. Is there an update for the firmware for this particular tv???
Dec 26, 2010 | Televison & Video
Needs codes rca remote
I'm not sure which remote and device you have. The header says a GE remote and the text says RCA remote. I'll provide locations for both types of remotes.
Try the following web site: http://remotefinder.rca.com/default.aspx?site=rca for RCA universal remotes. Enter the model of the remote as well as the brand and type of device to be controlled.
GE Universal remotes use either a three or four digit code. Find the code lists here: http://www.jascoproducts.com/support/universal-remote-codes.asp . Then determine if you have #24912 remote or which of the remote code lists that applies to your remote.
The code lists for any given remote will be limited to codes for devices released 6 months or more before the universal remote was programmed. If your device is newer than that date, the codes may not work.
I hope this helps.
Nov 20, 2010 | Universal Remote Control GE174Universal...
I have a universal remote and need the code for a magnavox dvd player to program the dvd player thank you
To get the code please go to below website
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 28, 2010 | RCA RCU404 Remote Control
Need code for universal remote by rca
Please
device to be programmed(VCR,TV)
Thanx
Jul 26, 2010 | RCA Universal Remote Control
I lost my remote and need a remote code for a universal remote
To get the codes for your TV
Please go to below website
Select the remote control model,Device and Brand,It wil give you the code.
Thanx
Jul 23, 2010 | Coby TVDVD2050 20 in. TV/DVD Combo
Unable to turn magnavox TV on. Child lockout is on and unable to turn on TV. Do not have original Magnavox remote. I do have a Universal RCA Remote. Can you give me the code for my RCA Universal...
What brand is your universal remote? Best thing would be to go on the universal remote manufactures website and they should have a list of codes for models based on what model number your universal remote is. Then you can look up possible codes for your tv found in the users manual (which you can print from online) and it gives you like 5-7 codes that you try and will give you instructions on how to enter the code and save that code to your remote. I hope that helps.
Aug 16, 2009 | Philips Magnavox 27MS343S 27" TV
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Jul 09, 2009 | RCA Universal Remote Control
Need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
May 17, 2009 | RCA 3-Device Universal Remote with...
Unable to program universal remote with phillips TV.
Todd, there is a web site you can go to. replacement remotes.com Use the top site when it comes up. At the top type in your remote model number. You can purchase a manual or maybe call the # I found the item# you want is 61369 for 3.95 Sorry this is all i could find. good luck
Feb 12, 2009 | RCA Universal Remote Control
RCA Gemstar F32450 TV can not get the TV to display the DVD menu
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts. ..
Mar 01, 2017 | RCA F32650 32" TV
Televison & Video Logo
163 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
