Question about Biostar Computers & Internet
How can i fix slow data transfer to my flashdrive on my biostar mgv-h61 motherboard
I have a biostar mgv-h61 motherboard with usb2.0 ports it takes 20 minutes to send a 1 gigabyte file to my flashdrive the highest rate i 4megabytes p/s how can i fix my problem
How do i fix my usb slow data transfer speed
Make sure that JUSBV1: Power Source Header for USB Ports Pin 1-2 Close: +5V for USB ports at JUSB2/JRJ45USB1 If the jumper is on 2-3 the standyby section may not be providing enough current, thus causing the problem. With some USB devices this problem of high current demand is so severe that a USB3 add in card has to be put into the system to meet the current demand. The USB3 cards have a receptacle on the rear of the card where one of the power supply Molex cables is plugged in. This ensures adequate current and voltage. USB3 can provide 1.5 Amp, USB2 only 1 Amp.
Jul 22, 2015 | Biostar G31D-M7 Motherboard
Disable log in
thats how it is done but you can take it out from start up go to msconfig then to startup uncheck hotmail
Mar 26, 2013 | Biostar H61MLV LGA1155/ Intel H61/ DDR3/...
Install hitachi p7k500 full speed
Your motherboard MUST have a SATA 3.0 port. It is usually blue or look closely on the motherboard to see where the 3.0 port is located. If your motherboard doesn't have a 3.0 port your hard drive won't be any faster than a normal hard drive.
Feb 09, 2018 | Hitachi Deskstar P7K500 (HDP725050GLA360)...
So i want to reboot my Mainboard Biostar H61 but i've lost my cds, What do I do ?
Hello you can download the drivers here:
http://www.biostar.com.tw/app/en/support/download.php
The full mainboard number is printed around the pci socket.
Remember to select your operating system.
The drivers may need to be unziped before installation
Jul 17, 2012 | Biostar Computers & Internet
Pendrive working slow....in biostar g31 m7 te
Go here and get the chipset driver:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=363&tab=3
May 19, 2012 | Biostar G31-M7 TE Motherboard
Drivers descargar
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
You can also try Driver Guide for drivers at:
http://www.driverguide.com
May 16, 2012 | Biostar H61-ML H61ML Desktop Motherboard -...
I need a usb 2.0 driver for my biostar U8668 mother board
when u power up the computer press "del" or F2 kewy to tenter in bios then go to usb configuration then set high spped in usb 2.0
May 06, 2009 | Biostar U8668 Motherboard
How do you install and use a USB Flashdrive
just try this one. try to insert your flashdrive to a usb port where it is compatible then a message will appear saying open folders to view files then you can now copy and paste a pictures or songs on the pc or on ur flashdrve.
Feb 25, 2008 | Electronics - Others
Computers & Internet Logo
91 people viewed this question
Top Biostar Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Davit Mamyan
Davit Mamyan
Roy May
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
