Question about Samsung HLR5067WX 50" Rear Projection HDTV
When powered on screen appears and then goes off. The standby/temp - timer - lamp lights blink
Standby/temp = green timer = red lamp = red
Posted by Jim Ryan on
5 Related Answers
SOURCE: t.v. will not turn on. flahes "lamp" then no picture!
I have a picture but the tv will periodically turn itself off during the day and then flash the 3 blinking lights...anyone know what the problem could be. We can fix it ourselves if we knew for sure what it is.
Posted on Jun 06, 2008
Nick DelRegno
  • 49 Answers
SOURCE: Turning off
Three blinking lights indicates a lamp problem.  This can be from A) a bad lamp, B) bad ballast C) bad Light Engine/DMD Board.  Try replacing the bulb first.  As with any lamps, it has a limited life.  If that doesn't work, you can try the ballast next.  If that doesn't work, it's time to take it in to a certified repair center for diagnostics.  Here is a page from the service manual on the three blinking lights.
Posted on Jan 24, 2009
Rexter1
  • 40 Answers
SOURCE: Immediately Shuts off with blinking light codes
I suggest doing a google search using the tv model # and brand.
I have learned myself that different big screen tvs seem to each have their own common problems. I have read before of power supply issues that cause what your describing.
Posted on Mar 11, 2009
TONY BIGNELL
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
Anonymous
  • 53 Answers
SOURCE: sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Posted on Apr 23, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
1helpful
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Put a new bulb in that i got from e-bay, tv switches on perfect but after a little while it turns itself off then red and green light start to flashing. i don't know what the problem is ????
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions (for samsung) :
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Below are conditions lamp indicators that appear blinking and solutions:
Thanks.
When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
http://tvtechwork.webs.com/
1helpful
1helpful
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Samsung HLR5067WX 50" Rear Projection HDTV Logo
Ekse
Demonic-2011
Demonic-2011
