Question about Dometic RM2652 Refrigerator
Why doesn't it cool or freeze?
The auto and gas lights work.
Posted by Randy Kelley on
1 Related Answer
SOURCE: NDR 1292 - Was freezing/cooling
NDR 1292 won't come on.
Posted on Dec 01, 2011
My dm2652 turns on but doesn't cool
Check the thermostat setting and check you have power from it to the heater if it is an absorption fridge or compressor if not.
Apr 21, 2012 | Dometic RM2652 Refrigerator
NDR 1292 - Was freezing/cooling on electric, but stopped freezingcooling, tried gas but doesn't freeze or cool
Since it does not work on either AC or gas - do you have DC to the unit? I have spent many hours troubleshooting a Dometic that turned out to be a corroded DC connection.
Jul 26, 2011 | Dometic NDR 1292 Refrigerator
Dometic Americana RM2852 refrigerator does not work. Has power to it, light inside works and lights at top indicating 'AUTO' mode are illuminated, but refrig doesn't work in any mode. Gas is...
Have the same unit but experience no problems. Sounds like a freon leak has left it inert. You can of course switch from auto to gas and eliminate the auto switch over as part of the problem. You can see the gas flame in the outside access hatch, (or maybe hear it) to be sure it is getting gas. since it doesn't respond in auto, which would also work in electric mode, I think it is the freon problem.
May 11, 2011 | Dometic RM2852 Refrigerator
The bottom shelves of my freezer are not working, its not freezing the food.
Possible that the compressor is not having the needed pumping pressure. So check if there is frosting within the freezer , a clear case of auto defrost not working. If so shut down for 6 hours and start, if cooling returns to tray then check on the auto defroster timer, the thermostat or the heater. If there is no cooling still the compressor or the gas pressure is down. Fill after confirming there is no leak.
Sep 14, 2010 | Refrigerators
Both sides stoped cooling and freezing
Well, it needs gas for it to work. try to buy some.
Nov 01, 2009 | Samsung RS265LABP Side by Side...
Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Sep 23, 2009 | Refrigerators
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Dometic RM2652 Refrigerator Logo
128 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
