RCA remote control have no set-up code to Vizio.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
SOURCE: cant program Vizio TV using RCA universal remote RCR312W
can i program an rca remote to a vizio tv?
SOURCE: son was using x-box with
Sounds like the x-box. Try hooking up a DVD player to it and see if you can get a picture from it.
Restart the x-box, and maybe get a can of air to blow the dust out of it.
SOURCE: Vizio E322VL occasionally loses it's sound. It
It can be the 12vdc power supply for the amplifier is dying, or dying power amplifier (Class D amplifier), or sound processor.
Does it do this on all modes (I.E. TV, DVD, etc)
When the sound goes out you can try this to narrow down the causess:
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find. You may be better off if the sound does work through the PC speakers, to get the TV repaired; it will be more than $100 and up.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: Ever since I connected the
For a remote to command another device than its own it must be programmed. Unfortunately the remote of the Vizio E322VL tv cannot be programed, it's good only for that tv.
But the remote of the Cox box is programmable and it supports the Vizio tv's like yours. Since you don't know the exact model of your remote you will have to go here
http://ww2.cox.com/residential/centralflorida/support/tv/article.cox?articleId={565a9f10-69b9-11df-5fca-000000000000}
find your remote and below it you will find the instruction manual on how to program it and the specific codes - the general Vizio ones, that apply to all remote models are 0030, 1758, 0178, 0864, 0885, 1756.
