No fuses in a camera. Check the battery first to determine if it is fully charged. THen check the contact points on the battery and in the camera. ALSO....be sure you are putting the battery in correctly.
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
check out if the battery is fully charged.and even if the battery is very old it does not get charged completely so replace the battery and checkout it should work.
Possible failed battery showing fully charged but actually not -or even charger.No reset]
Disconnect from the wall socket- re connect and tell us if the battery is now charging.
If show full- replace battery.
Also tell Sony customer support
