It prints more of red color, and when combined the black color doesn't print unless i made its out line thick
Run a gradation test, might require a tech to access service mode,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Black lines running down the prints
it seems that your print head is the problem you can try to clean it first..
but if you already try to do this no other choice is to have a service center o change it for you.
thanks,
SOURCE: Faint red line across page when making color copies or printing in color from computer
Some possibilities are:
1) Dirt on the glass, dirt on the glass strip for the doc feeder, or dust on the mirrors. This would be the case if the line only showed when copying and not printing.
2) Toner dropped onto the charge sawtooth.
This may be possible if the line is intermittent and only showed up for 1 or 2 colors.
Open the front door and remove the waste toner box. To the left of each drum there is a green organ-stop type stem. Pull and reinsert each stem. You will hear a zipping noise. These are your charge scrubbers.
This may be not as likely if the line shows up in the same place on all 4 colors
3) Toner or dust on the lens
In the area where the waste toner box goes, look for a grey stick with a white cushion on the end. This is your lens scrubber. Look in the area under the charge scrubber on each drum cartridge for a gap. Insert the scrubber cushion side down into the gap and run it forward and back to clean the lens.
4) Transfer belt blade not cleaning
This is best handled by a service tech since the mylar belt is very fragile. The squeegee blade that cleans the transfer belt between copies is missing a spot. The blade needs to be taken off the belt, cleaned and repowdered. Recently, Sharp made changes to the composition and thickness of the mylar in the transfer belts. Overpowdering the blade or belt when it was changed may cause improper cleaning of the belt creating lines across the copies. Often the condition clears up after a couple of days as the gap between the blade and belt is sealed.
This is most likely the cause as the line shows up in the same area for more than 1 color.
5) Transfer belt and/or blade is worn out
If the belt is worn the blade must be replaced but not vice versa.
6) Clogged waste augers in the drum cartridges.
Waste toner may cake up in the drum cartridge and knock loose on the drum.
It may be time for full maintenance on the machine.
SOURCE: how do i print with color on this machine?
This machine (Sharp AL 1530CS) is a black and white printer/copier but can Scan (not print) in colour. It only has a black toner so will never print in colour...sorry
http://www.sharp.net.au/cms/products/4011/downloads/AL1530CS_Brochure.pdf
Testimonial: "Thank you an old one but a good one i suppose. "
Cleaning the Print Cartridge Nozzles:
1.
Open the Lexmark Solution Center. Click Start > Programs or All Programs >
Lexmark 1300 Series. Select Solution Center.
2.
From the Maintenance tab, click Clean to fix horizontal
streaks.
3.
Click Print. A nozzle page
prints, forcing ink through the nozzles to clean the clogged nozzles.
4.
Print the document again to verify that print quality has improved.
Using the control panel
1.
Press Menu.
2.
Press the down arrow button until you highlight Clean Cartridge.
3.
Press Select. A nozzle page
4. Print the document again to verify that print quality has improved.
