Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
My picture has a double vision effect. I have been told that it's the bulb. True or some other fix?
Posted by Jeff Landry on
3 Related Answers
Anonymous
  • 105 Answers
SOURCE: double vision
replace the stk ics. they are located inside the tv with lage heat sinks. i do believe sony runs stk392-510. youll have to look at the ics to know which ones for sure.
Posted on Oct 13, 2007
Anonymous
  • 250 Answers
SOURCE: Double Vision....
The double vision or ghosting is normally bad IC's. These are two large chips connected to two large heat sinks. You'll need to find the numbers printed on the chips and buy replacements. You will also need more heatsink grease to put between the new chips and heatsinks so don't forget to order that. It's a pretty easy fix and if you do a search here you will find tons of information on IC's replacement. Hope this helps.
Posted on Jul 07, 2008
Anonymous
  • 82 Answers
SOURCE: sony tv is having double vision, I tried to focus
I would try to clean the projection lenses before I replace the tubes. Try usiong alcohol and q-tips. Good luck!
Posted on Mar 14, 2010
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
5helpful
4answers
Double vision
I have a 60SBX72B and the colors are all separated like triple vision. Is there a way that I could fix this
Picture is in showing in double vision with colors serperated
bulb is going out. go back to where you bought it to see if warranty will cover it. if not, buy another bulb. ours was like, 40 bucks.
Double vision on jvc 48" rear projection television
No that is not correct
The problem you describe is a convergence issue which can be quite costly. The alignment alone is very complicated and more importantly time consuming
Too much red + double vision viewing
This seems to be a convergence failure on your TV.
If you have hand basic soldering skills and a soldering iron, this might be something you can do.
Check this link for the parts you need.
Goo Luck.
3answers
Double Vision....
the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
2answers
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Top Sony Televison & Video Experts
Jaime Hernandez
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
