I am unable to get online. Signal strength through my router is excellent
Posted by Amy Jones on
  • 7,733 Answers
Posted on Sep 13, 2015
5 Related Answers
marked
Mark Gil
  • 6487 Answers
SOURCE: Weak connection with my xbox 360
The best way to make the wireless connection stable is to do some changes on the wireless settings of the router , like changing its wireless channel to the highest one to avoid any interference on your area.........
Posted on Nov 05, 2008
CampinFamily
  • 19 Answers
SOURCE: Error code 109 D-Link Router DIR 109
can you connect to the router interface? what does it say the wan status is?
Posted on Mar 12, 2009
Anonymous
  • 53 Answers
SOURCE: signal strength keeps varying
if you arent in a clear line of sight, many things can affect the signal strength of your network including the thickness of the walls, the composition of them and anything else that may be in the way. if you use a 2.4 ghz router and you have a 2.4ghz cordless house phone, they can interfere and cause issues. A microwave oven that is located between the router and a device can cause interference as well.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
Posted on Jun 10, 2009
Frank
  • 244 Answers
SOURCE: have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Posted on Jun 28, 2009
jepito
Kevin Groce
  • 216 Answers
SOURCE: how to connect to xbox live through sky sagem
reset the router to default settings first...
Posted on Dec 27, 2009
I am unable to go online. Signal strength through my router is excellent
1) Check if the network cables attached to your wireless routers are connected properly.
2) Check if the internet connectivity LED flashes, if not then there is an issue with your internet and you need to call your Internet service provider.
Aug 12, 2015 | Supersonic 7" Touch Screen MID Tablet
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Router says connected, laptop picks up signal with excellent strength. But when try to connect says unable to...have used this connection for a few years now and suddenly went off last night
k i understood your problem. try below.. 1. Restart your computer and chk whether you can go online. 2. If still not online, go to command prompt, type in ipconfig and press enter, if u see an IP address, subnet mask and gateway, then u need an either a firmware update/ a reset. 3. Contact belkin support which is a toll free number, they will assist you futher.
Oct 09, 2010 | Belkin Computers & Internet
Very low signal
Given that you have a '802.11B' device, the maximum speed will be 11 Mbps.
While your wireless router is communicating at that speed to your computer, the router is communicating with your ISP at a much-lower speed, depending on how much you pay per month to your ISP for the agreed-upon level of service, e.g., "ADSL-lite" or "High-Speed".
So, unless you pay more per month to your ISP, the "bottleneck" will be between your ISP and your router, *NOT* between your router and your wireless adapter.
Now, as to the "low signal strength", that's a matter of the distance between the router and your computer, and the number and composition of the walls and ceilings in the middle.
If you move your computer closer to the router, the signal-strength should become "good" or "excellent".
Nov 06, 2009 | Microsoft MN-510 802.11b (L21-00002)...
Signal strength has fallen from excellent to very low. strength on laptop and desktop pc remain excellent. Sounds like a NB100 glitch, but what?
As i understand your concern that on your laptop and desktop pc you are getting excellent signals so it might be possible that your third device required to upgrade the drivers for that. Because sometime it happened that the device driver not working properly.
Oct 27, 2009 | Belkin Computers & Internet
Was working ok, now cannot get online using belkin modem-router. Says I am connected to my network, "signal strength excellent" but no wireless connection. Using the Belkin Modem router I am unable to...
please try to reset your router.
on the back of the router there is a little hole where you can insert a pen or a paperclip. hold it pressed in for 30 seconds and then release.
wait 10 minutes and try to connect to internett again (after connecting to the wireless net ofc)
May 28, 2009 | Computers & Internet
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
269 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
