Gbc HeatSeal Ultima 65 Laminating System Logo
Trisha Mattison Posted on Aug 12, 2015
Where is the fuse?
Reset several times but continues to turn off. I want to replace the fuse before replacing the machine. Where might I find it.
scott westin
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 02, 2015
scott westin
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
56452
Points
52
The Circuit breaker is located on the underside of the machine near where the electrical cord goes into the laminator. West Laminating Svcs 405-324-6092
2answers
Replaced fusing unitbizhub501 Can't reset. Researched online how to reset. This is ridiculous that you have to call a tech out just to reset the unit. Everybody is trying to make an extra buck.
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
FLASHING C50 ON SCREEN
Power off the machine hold down the stop button and turn on the machine that will reset the machine if it comes back the fusing unit needs to have either the upper fuser roller replaced or the thermistor need to be replaced or the power board needs replacing DO NOT CONTINUE TO RESET it can catch on fire that would ruin a perfectly good day!
I have replaced....several times.... the 15amp fuse for my turn signal and overhead console read out and they continue to blow. All other lights continue to work, even the flashers, head lamps, and break...
When a fuse blows you have 2 choices
Replace it once or just go to the wiring
diagrams & start diagnosing & testing,
until you find the cause of the electrical
system problem causing the high current
You need to know what is on that fused circuit
Unplug the overhead console. If the problem
goes away, you know the console needs to
be checked out. Or you work on the signal
problem WITH WIRING DIAGRAMS
You wouldn't go on a road trip without
a map,if you never been there before !!
2answers
My < year old DeLonghi
If the light comes on and the coffee is not brewing than it is the heat plate temperature fuse. You need tamper torx bits to open the bottom unit and replace the fuse, radio shack sells them. I have had to change several of these on Delonghi products. These are mechanical connections and the leads need to be crimped properly or the unit will fail.
Xerox FAXCENTRE 2218 Drum Warning displays on
Often times with that machine, if you replace the drum before it says replace, it will not reset.
3helpful
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
Continuous flashing green "timer" light on front, tv won't reset
Is your set a mitsubishi/ If so you need a DM repair kit they have various kits for the different mitsubishis at the following link under the repair kit category. The kits contain the replacement capacitors and instructions on CD.
http://servicemanuals.vstore.ca/
Top Gbc Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
bvmihai
Ngoro
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
