Question about Panasonic PT-50LC13 50" Rear Projection HDTV
TV will not turn on-- clicking noise in the back
I have a Panasonic PT-50LC13 and it does not turn on. It used to work just fine until today. I have the TV for 4 yrs. When I press the ON button the light turns green and it blinks and the clicking noises in the back start. after a few cycles of clicking noises the light turns red and it blinks.
Could someone help me with this issue? Thanks!
Posted by mihainegru on
  • mihainegru Nov 15, 2007
    Do you know where I can get the part and what is the part number?
Anonymous
    Sergeant:
    Champion:
  • 306 Answers
The power pack the the power cord goes into has gone bad and needs replaced, see manufacturer for service or parts.
Posted on Nov 15, 2007
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic TV has sound but no picture
same problem here mine is not a plasma just normal tv was working all fine turned it off came back in an hour turned it on just black screen all channels work with all sound
Mar 11, 2010 | Panasonic PT-50LC13 50" Rear Projection...
TV shut off and cannot turn back on
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.The part # for your lamp is TYLA1000 you can find it here:http://www.discount-merchant.com/Panasonic-TY-LA1000-Lamp-DLP-TV-bare-lamp-p/panasonic-ty-la1000-lamp.htm Good luck and God bless you!
Feb 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
NEW BULB INSTALLED FOR PANASONIC PT-50LC13 TV STILL NO LIGHT
close lamp door set will not work with door open. if not that listen for arcing sound in back if  don't hear that bad ballest
Jun 09, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset Time Problem on Panasonic TV (PT-50LC13)
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
Jan 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13
The ballast probably needs to be repaired. A repair kit #LSUC0022 is available from Panasonic.
Jul 18, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
427 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
