Question about Toshiba E-Studio 356 Multifunction Copier
Why is it indicating that tray 1 is empty when there is, in fact, paper in the tray?
We have tried resetting the computer, but it is still not working. There is not a paper jam, tray 2 is working fine, but it will only allow us to print legal size for some reason. The printer settings on the computer are all correct as well. Please help!
Posted by vineyard on
Asghar Nadeem
    Champion:
    New Friend:
  • 245 Answers
My dear you chek paper motor pic lift
Posted on Aug 12, 2015
HP LaserJet 4200 - need help resetting default tray selections
Are you using Window 7 64 bit or 32 bit? Re-install drivers appropriate for that version of your operating system. Also look at the "Paper Handling" section in the printer menu. Be sure both trays are set for "Plain" paper.
Jul 20, 2010 | HP LaserJet 4200 Printer
F3 ERROR CODES
This code indicates a fault with the paper tray lift-up motor. F3-12 = tray 1, F3-22 = tray 2 etc. To clear this fault switch off at the power supply and empty the indicated tray of all apaper and jams. Operate the lift up section and then close the drawer with NO paper in drawe. Switch on again and after the machine boots up replace the paper in the drawer. This usually works fine unless there is a serious problem with the lift-up motor.
Feb 19, 2010 | Sharp AR-5320 Black and White Copier
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Kyocera FS-920 RED LIGGHT IS BLINKING AND GREEN LIGHT IS OFF
There are 2 possibility to cause your printer acting like this:
1) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
2) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
If it is condition 1) then just remove the jam paper then open and close the Top Cover to clear the error.
If it is condition 2) then insert some paper in the paper tray.
YBC (/\)
Jun 05, 2009 | Kyocera FS-920 Laser Printer
Error msg: paper jam or empty paper cassette when it is full
Click on the 'feed switch' on the front control panel- it might be feeding from the invisible drawer underneath and it might be empty. There is a light which will indicate which source it is feeding from.
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
Toshiba E-Studio 356 Multifunction Copier Logo
126 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
