Refrigerators Logo
Simon Williams Posted on Aug 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water is collecting at the bottom of the fridge under the salad trays constantly
Water is running down he back of the fridge and collecting at the bottom, some times there are pieces of ice, it is on number three and the green light is not on. the round button at the top is not pushed in.
Ross Keen
Level 3:
  • Master 1,365 Answers
  • Posted on Aug 11, 2015
Ross Keen
Master
Level 3:
Answers
1365
Questions
0
Helped
583344
Points
2445
Whenever that happens on our fridge we find that the drain out the back is blocked. Have a look inside the fridge on the back wall, you may see some guttering that guides the inside moisture to a hole. That hole drains to a pan on top of the motor. Heat from the motor evaporates the water. I have always managed to clear ours by poking a bit of flexible wire down the hole. It's not a frequent occurrence, probably 7 or 8 years between blockages.
Testimonial: "Thank you for your advice I will try that, the fridge freezer is not that old."
4helpful
Water collects in the tray below the produce trays
you may have a block in the drain so instead of the water running through the back hose its runing down to the bottom of the fridge look for the little hole inside the fridge it will have runners at the back to guide the water
1helpful
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
2helpful
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
1helpful
Water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
9helpful
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
5helpful
3answers
Hotpoint RFA 60 Refrigerator drain problem
Well the only way to check it out completely is like you said going from inside your freezer and I like to pour water down the line to make sure it drains.
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it.
If the opening is clear just pour water down and observe the drain pan under the unit and see if it comes in there.
9helpful
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
3helpful
2answers
Water pooling in base of fridge
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
