Question about GE Microwave Ovens
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
I have a GE XL1800 Spacemaker microwave that is not working. After setting the COOK time and pressing start, it will turn on for about 1 sec and then immediately goes off. The display comes back with PRESS CLOCK. After setting the clock and trying to use the microwave, the same thing happens. The light turns on and then goes off. The display shows PRESS CLOCK again.
    Sergeant:
  • 268 Answers
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Posted on Oct 09, 2017
2 Suggested Answers
6ya staff
SOURCE:
robb2004
  • 15 Answers
SOURCE: reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
Posted on Oct 23, 2010
Turn table does not work. How do you fix it? I have a GE Spacemaker XL 1800, Model # JVM1842BD. Thank You
i have a ge 1800 model and it cooks fine but after awhile it shuts down and in about a hour it comes back on and ask you to set the clock.....
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
FAN STAYED ON, PRESSED ALL BUTTONS, DISPLAYED SAID "LOCKED CONTROL" ONLY CORRECTED TO NORMAL CONDITIONS, BY CYCLING BREAKER. WHY DID ITHAPPEN AND IS THERE ANOTHER WAY TO CORRECT THE PROBLEM? GE SPACEMAKER...
Sometimes a random glitch will cause this, and a "hard reset" (cycling power) fixes it.
Other times, you may have a failing controller.
If you continue having trouble, feel free to get free assistance here.
Jan 31, 2010 | GE XL1800 1100 Watts Microwave Oven
Our GE Spacemaker XL 1800 microwave's controls are locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 Micro - " Turns itself off after 2 sec. "
It looks like a component is short-circuited and then it acts to protect. Call a service.
Sep 21, 2017 | GE XL1800 1100 Watts Microwave Oven
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
