SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
SOURCE: Our American Standard toilet flushes
Okay Howard. It seems that the fill or float valve inside the toilet tank needs to be replaced. If you have a pair of channel locks / large pliers and some patience, you can do this yourself and save $ on a service call. This Solution is providing that you have good water pressure everywhere else in the house. First turn off the water on the supply line going to the tank. Flush the toilet (with the water off) to empty the tank. Take a towel / sponge / or wet vac to remove any remaining water. Remove the nut on the underside of the tank that holds the float / water supply to the tank. Now that you have the water float removed you can go to your local hardware store / Home Depot / or Plumbing Supplies Store and get a new fill valve. There are different kinds but they all do the same thing, fill your tank. I use a Fluid Master, But you may have to use one like you have. The Store will assist you. They are only about $10 - $15 Bucks or so.......Install the new float according to directions.....It is pretty simple. Insert your new float stem into the hole with the proper rubber washers and tighten carefully for a good seal. Insert the new black hose into the overflow tube and you are in business. You will have to adjust the water level to about a 1/4 Inch below the overflow tube for a good flush!!! I hope this helps you with the slow tank fill.............Joe
SOURCE: American Standard toilet constantly runs
The rubber cork thst lifts when you press the handle is leaking by and causes the water level to drop below shut off level so it trys to maintain the the shut off level every minute or so. Replace the cork with one made with the red rubber. good luck
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
