SOURCE: Dear all error code c970 Hvt
in the drum there is a pin make sure the drum shaft is making contact if the problem persists change the drum and blade make sure the main charge carona is not broken and the plastick hanger is not broken
SOURCE: Error code C970 on my
Check if the charger wire at the side door is broken or main charger grid is deformed.
& if any foreign matters are on the charger wire or main charger grid.
SOURCE: How can i fix the
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
SOURCE: resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
