Question about John Deere Garden
My John Deere la105 throttle control does not work. What's the fix? This is a riding mower
Posted by Chris kaatz on
David Kassin
  • 600 Answers
Check the throttle cable it may have come loose or broken.
Posted on Aug 09, 2015
5 Related Answers
rjnworbnhoj
  • 142 Answers
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Posted on Sep 20, 2008
Anonymous
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
Anonymous
  • 246 Answers
SOURCE: I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 17, 2009
mickey813
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
tfelton3
  • 183 Answers
SOURCE: John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
Posted on Apr 06, 2010
How do you adjust a clutch-brake on a John Deere LA105 mower?
Hello CherylPlazza,
Here's the Owner's Manual
John Deere la105 Manual
Read & heed (perhaps even make a copy)?).
Helpful...?
Carnac the Magnificent
Oct 17, 2017 | John Deere Garden
I have a John Deere LA105 and it is getting too much gas and coming out of the carburetor flooding it,I checked the float and it is fine,,,what else could it be?
I'd look at the valve needle and/or needlevalve seat. One or both maybe corroded or obstructed from free movement.
Feb 23, 2016 | John Deere Garden
John Deere LA105 lost power
Hi Hank:
Did you hit something with the mower, or did it happen gradually?
Probabaly a good idea to start with a basic service:
- Clean air filter
- Clean fuel filter
- Flush carbuerettor
- Fresh gas?
- Change spark plugs
- Change oil and filter
- Underside of mower deck clean and free of all built up grass?
Hope this helps.
May 09, 2015 | John Deere Garden
John deere la105 ride
need pulley puller to get off
Aug 17, 2014 | Garden
I need a wiring schematic for the LA105 John Deere lawn tractor
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=la105
Jun 14, 2014 | John Deere Garden
John deere model LA105, deck engagement cable spring keeps breaking.
are you routing it the right way rubbing or kinked
Apr 03, 2012 | John Deere Garden
My john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Jul 01, 2010 | John Deere Garden
Garden Logo
666 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
