Question about Danby Silhouette Series DBC514BLS 5.3 cu ft Built-in Beverage Center Cooler, LED Display, Lock & Key, Holds 112 Soda / Beer Cans, and 11 bottles of Wine, Instant Rebate Available
Purchased in 2010. Temperature doesn't fall below 55F. Fan works. Sounds like compressor is working. Haven't physically inspected compressor. Used to cool to 39F.
Placed a separate temperature gage in the freezer to compare Danby temperature. Danby: 55F - Other: 44F. Fridge is cool but not cold. Is this a compressor problem and/or a Thermostat temperature sensor issue?
Posted by Rick Pitre on
Lawrence Oravetz
  • Danby Master
  • 10,548 Answers
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Posted on Aug 09, 2015
GE profile french door fridge temperature problems
This type of clicking sound from the compressor is from the starting device. It could be a weak starting device or the compressor could be stuck.
Is the compressor hot?
Nov 01, 2012 | Refrigerators
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
Ge refrigerator won't cool. compressor doesn't come on
The compressor is gone, only option replacement.
Apr 18, 2012 | Televison & Video
The compressor and fan run but the refrigerator and freezer compartment do not cool down to an adequate temperature. The freezer does not get below freezing (32F) and the fridge does not get below 55F
Check your compressor for over heat (put your hand on it without burning)
Check for ice on back wall of freezer and on the freezer coils (defrost problem)
Check cond fan in back of fridge.
Clean cond coils
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
[email protected]
Aug 07, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
Sep 15, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
1993 CORVETTE AC PROBLEM
Are you fully charged though? If you don't have a full charge the clutch will not kick in.
Aug 18, 2009 | 1993 Chevrolet Corvette
Refrigerator is not cold (about 55F) freezer working ok both parts became warm last week for about 24hrs
A.Unplug the unit
B. get a air compressor with a air nozzel and vacume cleaner.
C. remove lower panel in back of unit to get to compressor and fan.
D. blow out any dust in coils and surrounding area. Clean fan.
E. put back panel/plug in and try
Aug 12, 2009 | Refrigerators
Refrigerator temperature stay at 55F.
sounds like a defrost heater located right behind the panel in the freezer section on the back wall. ($60 part)
Apr 25, 2009 | Kenmore Refrigerators
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Danby Silhouette Series DBC514BLS 5.3 cu ft Built-in Beverage Center Cooler, LED Display, Lock & Key, Holds 112 Soda / Beer Cans, and 11 bottles of Wine, Instant Rebate Available Logo
353 people viewed this question
Top Danby Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Moderator Canada
Moderator Canada
Are you a Danby Kitchen Range Expert? Answer questions, earn points and help others
