Question about Gaggia Evolution Espresso Machine
Hello :) after taking apart the machine for a derust service to the pump when plugged houses main safety drops.like a short circuit.can anybody help?
I just got a kitchen aid regency portable dishwasher. My guess is its around 20yrs old. The problem is after i push the button to start it it flips off the breaker in the house. I tried different plug ins...
Really sounds like the water has leaked into some part of the machine and is shorting out the electric, or, some part has frozen up.
By all means, do not use this machine until it is fixed, or you may actually start a house or apartment fire.
Oh, yes. We have one of these dishwashers we use every 2 days.
It could also be the case you have a 15 amp breaker, and should have a 20 for this machine; or, you have accidentally plugged this in the where a house/apartment circuit is protected by a GFI breaker, and they will not take a portable dishwasher.
Be blessed.
Apr 17, 2013 | Dishwashers
Samsung wash machine B12455 and it keeps blowing house fuse when i shut door and press start?
There is definatley a short in the main power section of the main controller unit. Usually this can be a surge protector or a possible short in the rectifier or a major SMPS power failure.
Unless the panel is removed this cannot be confirmed and so take precaution to test the panel for short in the main line circuit.
Jul 25, 2012 | Samsung Washing Machines
LG Intellowasher 7 kg WD-8013C power off (short circuit). When I turn on my washing machine, after 5 minutes, it power off. I have a short circuit somewhere, when started to load the water. Also I don't...
Hi Scutrera, You stated that when the machine fills with water that the unit switches off? sound like there could be a problem with the heating element. It may be that there is a hair line crack somewhere on the element causing the water to seep throught and make contact with phase which in turn trips the main RCD. Your best bet is to call up a local Appliance Service Technician to run a (PAT) test to determine if there is an Insulation breakdown with the internal circuit of the machine. I would strongly suggest getting profesional help when assisting in this matter as there could be fatal consequence if safety procedures and requirements arn't met, hope this helps.
May 01, 2011 | LG Washing Machines
I have a Lennox heat pump, approximately 15 years old. This morning I woke up and noticed that the house was cold. I attempted to raise the temperature but nothing happened - the heat didn't kick on and...
Something inside of the unit caused a direct short between the unit and that fuse box/panel. Usually a short that causes this much "fuss" is a dead compressor (worst case scenario). If there are no lights on at the thermostat then most likely the breaker for the furnace has tripped as well. There are 2 seperate circuits- one for the air conditioner and one for the furnace, they both tie back into the main electrical panel inside the house- wherever that is.
Hope this helps, James
Jan 05, 2011 | Heating & Cooling
The refrigerator keeps blowing the main electric to the whole house
Case Short Circuit in the machine. Please check the power cord, the plug and the connection at the end. Check for any loose/broken wire connections. Also Are you getting any burning smell near the machine when the fuse blows up, If so then wiring in the compressor is short circuited. You have to call a technician as you may not be having tools to check the short circuit.
Sep 16, 2010 | GE Refrigerators
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
House fuse box blows when you plug machine in.
There is a short in your vacuum that is cause your circuit to trip. It is more then likely a ground wire that has come loose in the plug that attaches to the motor of the vacuum
May 16, 2009 | Vacuums
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Gaggia Evolution Espresso Machine Logo
49 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
