Question about LG LS-L1210CL Mini Split Air Conditioner
WHAT IS THE MAXIMUM CAPACITY OF STARTING CAPACITOR AND RUNNING CAPACITOR, AND WHICH CAPACITY RUNNING CAPACITOR WILL BE SUITABLE FOR 1.5 TON AC?
Posted by SOHAIL on
william simpson
    Genius:
  • LG Master
  • 1,363 Answers
You can't mismatch capacitors on a unit. cause premature failure of componente in system
Posted on Aug 08, 2015
1 Related Answer
Bill Boyd
  • 53816 Answers
SOURCE: I WANT TO KNOW EVERY TYPE OF WINDOW AC AND SPLIT AC THAT HAVE RUNNING CAPACITOR OR STARTING CAPACITOR?
just about all on the market use start/run capacitors
Mitsubish AC Model FDC 51 BA Q.1: what is capacity of this AC in tons? q.2: what is running current in amps?
Here is a YouTube video that helps you calculate tonnage of an AC.
The only way to know the running current if it's not on the AC info plate with all the other info is to measure it.
Calculating tonnage of your air conditioner
Oct 12, 2017 | Heating & Cooling
Q.1 : Mitsubishi AC model FDC-51BA how much capacity this AC has in tons Q.2 : What is running current in amps
Oct 12, 2017 | Mitsubishi Heating & Cooling
What is the rule of thumb for computing the capacity of horsepower of air conditioner in terms of area, e.g. square meters
Horsepower does not necessarily matter. Horsepower is not computed to capacity. Amounts of btu/ heat removal, is measured capacity. 12,000btus which equals 1 ton of cooling will cool a maximum of 500 sqft depending on the heat load. Obviously a brand new home with updated insulation vs a closed in lanai with a wall of windows...you get the idea
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 22, 2017 | Heating & Cooling
What is the minimum volts required to run 1.5 ton 5 star AC?
Low voltage will burn out all the motors Higher currents will ruin the start capacitor on the compressor and fan motors too. 220 vac is the minimum. You have to allow for inrush or start up current which most likely is the cause of the under voltage. You'll have to get a larger capacity stabilizer.
May 25, 2016 | LG Heating & Cooling
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
Weatherking 3 ton Run Capacitor
Could be; age,lightning,power surge,defective wire,loose wire,tight compressor. Capacitors fail sooner or later. They are like batteries they do not last for ever.
Aug 04, 2009 | Weather King Heating & Cooling
What wire size do I run for a 3 1/2 ton AC unit?
it depends on the distance from main power source # 8 if more than 40 feet look at starting amps then google a wire sizing voltage droop chart
May 08, 2009 | Heating & Cooling
Amana 1 ton Residential AC / Outside unit comes on for a sec
open the service panel to check for control voltage of 24volts when tstat calling, The contactor should be pulled in, if contactor is down,and contacts appear to be clean, and the unit is still not running, it is a bad compressor. to test this unplug the black wire from the compressoror at contactor,w/ power off! Turn on power if fan works normally it's a bad compressor. However if you see a swollen split cap(5 wires to a soup can looking w/ the terminal C,F,and Comp), switch it first and start at square one.
You also need to consider the high pressure switch if its cycling on off on off.
Mar 12, 2009 | Heating & Cooling
No problem,just confused.
You will usually find that it is the model number.
Or maximum total weight of vehicle.
Check your drivers manual
I had a dodge ram 2500, which only had a 1/2 ton capacity.
good luck
Jan 25, 2009 | 1993 GMC Sierra K1500
LG LS-L1210CL Mini Split Air Conditioner Logo
109 people viewed this question
Top LG Heating & Cooling Experts
Marvin
Marvin
Steve Oakes
Steve Oakes
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
