Question about Pets - Others
All Living Things Wrought Iron Small Animal Home
I need to replace the plastic tray that was warped in the sun. How do I get one that fits? I do not know the measurements because it does not say on the box and I cannot measure my warped one.
Posted by Akiko Kasumi on
LaceyLaPlante
    Problem Solver:
  • 8 Answers
You can try straightening it out by pouring a pot of boiling water over it then bending it back. It probably won't go back to normal but you can get close enough to the measurements.
Posted on Feb 05, 2020
5 Related Answers
David Shaub
  • 2976 Answers
SOURCE: Lost the plastic measuring cup for rice cooker/steamer
How many cups of rice did you use compared to water. Use the same number, using anything from a teaspoon to a small soda bottle. The rice doesn't really care how it gets measured.
Posted on Jan 17, 2009
chrisbock
  • 199 Answers
SOURCE: I do not have the plastic measuring cup that came
2 to 1 ratio 2 cups water to one cup rice some other rice have slightly different ratios but the standard is 2 : 1
Posted on Jun 24, 2009
Anonymous
  • 10 Answers
SOURCE: subwoofer for mitsubishi l200
Go on craigslist there is custom built boxes on there alday long for sale, cheap to. http://louisville.craigslist.org and just find the state your in.
Posted on Sep 23, 2009
Anonymous
  • 5 Answers
SOURCE: o-ring measurement tool
Either a Vernier caliper or a micrometer.
Posted on Apr 21, 2010
lmmuresan
Laura Muresan
  • 131 Answers
SOURCE: The measuring cup has been lost. Are there replacements available
You can sometimes find them here: http://stores.ebay.com/Lauras-Last-Ditch/Bread-Pasta-Machines-/_i.html?_nkw=pasta&submit=Search&_fsub=360500719&_sid=93311479
Posted on Sep 09, 2010
How do I mount a 32" Wrought iron pendulum wall clock?
studs r on 16" centers (usually).
hanger needs to be secure in a stud and sized for clock weight.
hanger arrangement depends on clock config
plan on removing clock from wall to replace batteries.
Sep 21, 2014 | Sterling & Noble 20 Wrought Iron Wall...
How put the fixture cover back on?
are there any clips on the fixture that hold the cover, if not, the cover probably wraps on to the fixture.
Sep 01, 2014 | Kichler Lighting Home
Can a bending machine bend wrought iron?
yes, you can find benders that will bend wrought iron. some are only meant to be used on steel, but wrought iron benders do exist
Jan 16, 2013 | Tools & Hardware - Others
My wrought iron door has a tamper proof screw missing. Can I replace it with another type of screw like a flathead or phillips head?
You can replace it with any type screw head. I would recommend however using a screw with the proper shank size. That is to say, a srew that is the same diameter.
Oct 07, 2012 | Smedbo Door Knob in Wrought Iron
How should I maintain my Wrought Iron outdoor chair?
In order to maintain a wrought iron outdoor chair you should use paint to touch up the cracks and afterwards apply rust protection. Moreover, you should wash the chair with a mild soap and rinse once a week.
Sep 02, 2012 | Alpine Garden
What are the benefits of Wrought Iron outdoor chairs?
Wrought Iron outdoor chairs can be mounted on wheels, they are very sturdy and durable and they are available in a wide range of designs.
Is it possible to paint over my grandmothers old wrought iron bed frame? It is in great condition and the size is right, I would just rather something a little brighter.
You need to buy a special paint for metal with special additives that prevent rust. Make sure to also buy a primer that is compatible with the paint you have selected. I found you some great instructions that should help you out.
• Wipe the wrought-iron bed frames with a rag that was dipped in mineral spirits. That will help you to remove all traces of oil and grease from the frames.
• Scrape rusty areas with a putty knife or scraping tool. Remove all loose rust scale. Rub the surface with steel wool, too.
• Apply an oil-based primer. The primer needs to be designed for use on metal surfaces such as wrought iron. Roll on the primer with a small roller. Spread the primer with a paintbrush. Cover the whole surface with one coat of primer.
• Paint the bed frames with a finish paint that has a rust inhibitor within 24 hours of priming them. That will help the primer and paint bond.
• Roll on the paint in the same way you applied the primer. Use a paintbrush to make smooth, sweeping strokes to distribute the paint. Switch to a paintbrush with synthetic bristles if you decide to use a water-based paint.
Read more:
How to Paint Wrought Iron Bed Frames ' eHow.com http://www.ehow.com/how_7794293_paint-wrought-iron-bed-frames.html#ixzz232Q8GYhr
Aug 16, 2012 | Furniture
What kinds of materials are wine racks often made from?
THE BEST ANSWER FOR red wines are wine stones made of terracotta because of the porous and stable temperatures that will be the best of the best the most important difference is No rapid temperature fluctuation of temperature , but its not made for a sunny place in the room but the best option for in the living room or where to place at home .
Aug 15, 2012 | Furniture
Expanding hose cracked near top plastic juntion where alum pole slides in. Need to know if it's possible to remove hose from plastic, shorten slightly to replace split section and reinstall hose to...
I don't know if it's possible to remove. But, something I often use for cracked plastic is a plastic weld.
Just take a soddering iron and a cheap peice of plastic (I often use the clear constainers salad comes in) and melt it into the hole. It's an easy inexpensive way to fix things.
Dec 18, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Pets - Others Logo
592 people viewed this question
Top Pets - Others Experts
Tom Chichester
Ruth summersides
Kardoc
Are you a Pets - Other Expert? Answer questions, earn points and help others
