Does this P.C have an internal battery, and if so can it be changed
Posted by James on
Mister Danger
  • 5,631 Answers
Yes, laprops have a CMOS battery and it can be changed:
Tutorial How to replace the CMOS battery in your laptop
laptop cmos battery
CMOS battery hack Laptop CMOS battery
Acer Aspire CMOS battery Acer Aspire losing date
Maybe you even cen get a video for your make and mode of laptop, introducing in a ggogle search term
Youtuba, change cmos battery, your make and model of laptop
Posted on Aug 06, 2015
Time setting on camera is lost every time i turn off ,changed battery, with correct one
The internal battery is depleted. In some cameras it will charge off of the removable battery after several hours, if the internal battery is still good. Otherwise you must replace the internal battery which is a watch type battery.
Mar 09, 2015 | Cameras
Can the internal battery be changed
yes it can be changed, you will find that it runs on a nokia 3310 batery old tech but somehow there was an overflow in the stuff when 3310's was discontinued so they are stuffing these batteries into just about anything
Jul 17, 2014 | Tablets & eReaders
My internal battery is depleted. how do i change
Do you meant Korg M1 ?
How to replace Korg M1 internal battery, read HERE
FixYa can only give you the guide requested but for DIY, you are responsible for your own repairs.
Jul 24, 2010 | Korg TR76 76 Key Synthesizer Workstation
Internal battery dead,how to replace
The GPS 12 has an internal battery soldered to the board inside the unit.
I have replaced about a dozen of these over the years,
The problem is caused when the unit is stored for a long time without batteries.
The internal battery is not a rechargable.
You have to use a screwdriver in the crack that joins the 2 parts of the case and break the seal to split the case open.
This will of corse render the waterproofness of the unit void.
You then have to unsolder the internal battery from the board and find a replacement.
It is a tagged lithum battery, I can't remember the model at the moment.
Inside you will also notice the surface mount Intel 386 Chip. which is the main processer.
This has nothing to do with the battery but I found it interesting that a chip in a computer from the mid 80s worth over $3000 then, still has a use.
When you have soldered the new battery into place you need to either glue or tape the unit back together. Be careful not to damage the other parts around the battery.
Always keep charged batteries in the unit when not in use.
Hope this helps.
Alan
Apr 12, 2009 | Garmin GPS 12 GPS Receiver
Cannot take Garmin c330 apart to change battery
The internal battery on a C330 is not user replaceable. You will need to return the GPS to Garmin to have the battery changed.
Apr 04, 2009 | GPS
Pix lost from Kidizoom Camera
The instructions say that you will lose your pictures stored on the internal memory when you remove the batteries. Use a SD card instead of the internal memory, or download the pics from the internal memory before changing the batteries.
Mar 19, 2009 | Vtech Kidizoom Digital Camera
Cf-35 internal battery change
Carefully take it apart, find the battery, replace it, put everything back together, update the bios information, save it.
That's it in a nutshell.
Feb 21, 2009 | Computers & Internet
How do I change internal clock battery in sony trv68 hi8 camcorde
There is an internal battery, but it is a built in and I don't believe it can be removed. However there are clear instructions in the manual on page 69 that detail the steps you should go thru to recharge the exhausted lithium battery for the date.
Here's a link to the manual
http://www.henrys.com/manuals/sony/CCD-TRV58(En).pdf
Dec 11, 2008 | Sony Handycam CCD-TRV68 Camcorder
When battery is changed date and image size need resetting
Internal battery or capacitor may be bad and not holding charge to keep settings.
Oct 20, 2008 | Fuji FinePix F700 Digital Camera
Date/Time problem
Hi all, same problem happened also with my S304. I' ve deassembled it and there IS an internal battery on one of the pcb's inside. So, i'm sure that if this is replaced by a new one, this problem should be fixed. Replacement will be a little bit tricky as the battery is soldered internally. If i have found the right type of battery, i'll post it, but this can take a little time ;-) F
Apr 23, 2007 | Fuji FinePix S304 Digital Camera
Computers & Internet Logo
277 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
