SOURCE: False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
SOURCE: Canon PC-745 stopped working.. paper jam light
Sooner whole in трее there is what that subject , can broken part or scrap of the paper. Open and see attentively, in that place, where paper sticks. I for its work so much took out stranger a subject(
SOURCE: Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
SOURCE: When I load paper to print/copy I get a paper jam
Hello there
Would you like to try this.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: E,3 flashing on Canon MP140
http://www.devicemanuals.com/model/Canon_PIXMA+MP150_manual.html
How to reset printer canon pixma MP150
http://tricks-collections.com/reset-canon-pixma-mp150-mp160-mp170-mp180-mp450-mp460-mptool-software/
http://www.klinik-printer.com/2010/02/canon-pixma-mp150-service-manual.html
Service manual above, above that a repair site, above that is a forum for help, above that is your user manual
CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
