Question about Roberto Cavalli Clothing Accessories
Lost screw of my Cavalli Sunglasses
Dalia 517s
Posted by Xiaowen PENG on
Blair Miller
    New Friend:
  • 64 Answers
Sorry to hear that.
Posted on Dec 29, 2015
Roberto cavali sunglasses spare parts
I broke the rod of my roberto cavali,korumba sunglasse
/uploads/images/roberto-cavali-sunglasses-spare-parts-34960726-2-1.jpg
Apr 13, 2014 | Roberto Cavalli Clothing Accessories
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
Lost arm
then throw away and buy new ones
Mar 23, 2014 | Bvlgari BV 8022 Sunglasses
Lost screw holding in the lens for a Carrera 6
just go to an optichons like exspres sory but i can not spel to go but this shuod solve it for you
Jan 22, 2013 | Carrera 6 Sunglasses
My dog ate part of my sunglass and i want to know where can i buy replacement parts?
Well this all depends on the parts. Usally with sunglasses it is hard to find the part on your own. Many parts are irreplacable or its not even worth replacing. Especially if your dog chewed on them then you should just get new glasses.
Jun 19, 2011 | Roberto Cavalli RC 369S Sunglasses
My roberto cavalli sunglasses continue to loose their lenses.I need to contact customer service regarding a complaint.I'm not sure of the product number , however, they have the spaced frame with the lense...
hi
i understand ow much irritation it must be to you,please try approaching any other dealer with your lens if you are under warranty period i think you get it replaced .if it not under warranty and if the dealer dont stand by it .please try visting site which dealer with sunglasses replecement parts i think they can provide you solution and it will cheap
thank you
Dec 23, 2010 | Roberto Cavalli RC 451 Sunglasses
My sunglasses frame broke i need address for repair
sir
your sunglasses are branded Roberto Cavalli RC 451 Sunglasses so i request you to take the sun glasses to the show room where you brought it . they will have solution to your problem for sure.
if youare satisfied with my answer plsvote 3 thumbs up for it
Nov 28, 2010 | Roberto Cavalli RC 451 Sunglasses
Clothing Accessories Logo
1,104 people viewed this question
Top Roberto Cavalli Clothing Accessories Experts
JonSnell Electronic
JonSnell Electronic
legerdress
legerdress
Bandage Dress
Bandage Dress
Are you a Roberto Cavalli Clothing Accessory Expert? Answer questions, earn points and help others
