2008 Mercedes-Benz Viano 3.0 Logo
s
stan moolman Posted on Oct 14, 2017
Where do i find the switch that indicate the rear electric sliding door is open on my viano.
One sliding door shows 'open' although it is not. This cause the doors not to lock automatically and the interior lights staying on. The central locking does not work either.If I push the door hard from the outside in the last stage of it closing, I eventually get the door open light to go off.Can someone please advise where the sensor/switch is.
David Cocroft
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 14, 2017
David Cocroft
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
6288
Points
12
The door lock itself causes the light to stay on. Not cheap to replace.
5 Related Answers
Anonymous
  • 36 Answers
  • Posted on Nov 28, 2008
SOURCE: Auto electrical problems with 02 MB E320
Hi, you will have to get your car pluged into a Diagnostic computer with MB software.
It may just be a case of reseting the system.
But if it comes to the worst one of the SAM (can system) units has gone a little faulty & can only be replaced & reprogramed using MB computer system at a Merc garage or a top Diagnostic garage.
Anonymous
  • 6 Answers
  • Posted on May 10, 2009
SOURCE: Passenger Side Rear Door Will Not Open
If you can lower the window down you can jimmy it open from there preferably from the inside has more padding in the inside seal compared to the outside one i can see the switches working but some how it detached itself try and hook around the area were the door latch is not door hinges lol it wont be an easy task but a thin coat hanger as well as possibly a rubber door stopper to give ya some space to work with may help out good luck take her easy with the door stopper don't push it in too far may crack the plastic
Anonymous
  • 21 Answers
  • Posted on Aug 05, 2009
SOURCE: I have a 1995 Mercedes Benz s320 and my doors wont lock
There is a central door locking pump under the back seat, the motor has gone in it, cheap way to repair is to strip it down and put a motor in it from a tyre compreser from argos for under £10 very easy to fit just two wires
Anonymous
  • 1111 Answers
  • Posted on Aug 22, 2009
SOURCE: the rear passenger right hand door does not open with remote
child safety locks or bent linkage ?
Anonymous
  • Posted on Jun 06, 2011
SOURCE: Hi, My cars central locking
Replace Fuse 27 in main fuse box located under the hood black box in far right corner. Then try reseting your battery. Make sure to follow these steps as follow. Unhook the - then + of the battery. Clean both the negative and postive of the battery. Next go under the hood far right and replace Fuse 27 which is 15 type fuse green in color. Wait 20 minutes for reset of the computer then attach the + and - cables back to the battery.
2006 Mercedes Benz Viano. The electric sliding doors.
Question edited for clarity and add maker name.
Question moved to one of the 3 model categories, 2.2CDI, 3.0 and 3.5.
Did you fit this yourself? Take it back to the Installer. Check fuses, and relays.
https://www.google.com/search?q=2006+Mercedes+Benz+Viano.+electric+sliding+doors
Wiring Schematics
Transporters ā€¢ Electrical System VITO/VIANO (Model 639) ...
TECHNIrevue http://www.technirevue.com > revue_technique PDF
1 Use of wiring diagrams. 2 Abbreviations for wiring diagrams. 3 Location and assignment of ground points. 4 Location and assignment of plug connectors.
2006 Honda Odyssey slide door light on.
Here are the codes you posted along with the possible issues that may have caused each code to be triggered. It's possible the circuit these switches share has a problem that needs to be diagnosed.
It could well be a problem with the wiring or a problem with the connections between the switches and the Multiplex Control Unit, or possibly with the Multiplex Control Unit itself.
B1129
  • Driver Side Door Lock Knob Switch Signal Error
  • Faulty Driver Side Door Lock Knob Switch
  • Driver Side Door Lock Knob Switch harness is open or shorted
  • Driver Side Door Lock Knob Switch circuit poor electrical connection
  • Faulty Door Multiplex Control Unit
B2077
  • Right Power Sliding Door Remote Control Switch 1 Signal Error
  • Faulty Right Power Sliding Door Remote Control Switch 1
  • Right Power Sliding Door Remote Control Switch 1 harness is open or shorted
  • Right Power Sliding Door Remote Control Switch 1 circuit poor electrical connection
  • Faulty Right Power Sliding Door Control Unit
B2078
  • Right Power Sliding Door Remote Control Switch 2 Signal Error
  • Faulty Right Power Sliding Door Remote Control Switch 2
  • Right Power Sliding Door Remote Control Switch 2 harness is open or shorted
  • Right Power Sliding Door Remote Control Switch 2 circuit poor electrical connection Faulty Right Power Sliding Door Control Unit
B2079
  • Right Power Sliding Door Remote Control Switch 3 Signal Error
  • Faulty Right Power Sliding Door Remote Control Switch 3
  • Right Power Sliding Door Remote Control Switch 3 harness is open or shorted
  • Right Power Sliding Door Remote Control Switch 3 circuit poor electrical connection
2helpful
2answers
The doors opening warning light
Check/adjust the door locks.
Mercedes Viano 2013 Long diesel... Hi, my rear off side manual sliding door has started to 'pop' open during journeys of various speeds but normally longer journeys 20 miles plus...
You have a unibody vehicle. After running it, the heat will make it move/stretch. Things don't quite align properly. Think about it like your house when the sun sets and you start hearing it creaking and popping. Or between winter and summer, when the doors or windows don't close the same. Same applies to vehicles.
1helpful
The rear door on my 2010 highlander says it's open and getting nuisance alarms. I know the sensor is in the locking mechanism, however that part is $400. Where is the door ajar chime so I can remove it?
Here is what another Highlander owner said: "2010 Highlander 4WD: System check panel I indicating the rear door is open, when it's not. Been to dealer 3 times. Car has 6000 miles on it. The rear door open indicator effects door locking ability with key fob as well as continual chime indicating rear door is open in conjunction with turning dome light off and on. Dealer thought it was rear door strike plate. Adjusted accordingly. This was not the problem. 3rd visit to dealer still trying to pinpoint why this is happening so far no luck. Electrical bad door sensor faulty electrical door switch this problem is very annoying and now times consuming 3 visits to the dealer and still no solution. Rear door open indicator initially made to stop by rolling down driver side window at highway speed. Indicator also made to go off when road turns to the left only. <- " moisture causing short in rear door electrical switch" maybe.
something like this. You can remove it.
1helpful
Why won't my 2008 Town & Country Chrysler Van not start? Shows damaged key.
Security is set. If both keys register damaged. You have either a broken wire(usually by the ignition lockset/switch). Or the computer has died.
Electric drivers side rear door not operating nor rear suspension
look for blown fuses or burnt out circuit breakers..loss of power to these items..
The power side passenger door for a 2001 Chevy Venture van works every so often. The door doesn't move when the button is pressed on the panel in the headliner. The key remote doesn't work most of the time...
The proper way would be to look at a wiring diagram an test the electrical circuit's with a DVOM - digital volt ohm meter . Do you know how to test automotive electrical circuit's ?
Electric Testing Techniques You Need to Know
The Trainer 32 How To Read An Automotive Block Wiring Diagram
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter the vehicle info. year , make model and engine size . Under system click on body & accessories ,then under subsystem click on power sliding door . Click the search button then the blue link. Looking at the diagram you will see a control module is used .
Also reading factory service info. on how it works would be a good idea.
Rear Side Door Actuator Control Module
The rear side door actuator control module is capable of on-board diagnostic functions described in On-Board Diagnostic Features . The rear side door actuator control module monitors the door position at all times including during manual operation. After activating the on-board diagnostic modes, loosing battery voltage, or ground to the rear side door actuator control module the Power Sliding Door (PSD) Re-Initialization procedure must be performed in order for the rear side door actuator control module to correctly determine the door position.
Power Sliding Door System Description
The power sliding door system(s) can operate correctly only if the power sliding door is in proper mechanical condition. Any mechanical problems will affect the power sliding door operation and must be repaired before attempting to diagnose the power sliding door system. Manually open and close the power sliding door to determine if the door moves smoothly and without excessive resistance or binding. The power sliding door must also latch and unlatch without the use of excessive force. At any time during power sliding door open or close operation, excessive resistance to the door movement will cause the power sliding door to stop and reverse the direction of travel.
The power sliding door will operate only when the power sliding door on/off switch in the overhead console is in the on position. At anytime during power sliding door operation the on/off switch may be turned to the off position and the system will quit any function in process. The power sliding door will not open unless the transmission shift lever is in the park position and the door is unlocked. When the sliding door security lock is in the locked position the power sliding door will not open from the inside. The power sliding door close function will operate when the vehicle is in gear. The power sliding door module uses the VSS signal to determine if the vehicle is moving during a power sliding door close function. The momentum of the vehicle moving forward adds resistance to the door closing operation. When the rear side door actuator control module determines the vehicle is moving forward while closing the door, current flow through the actuator motor is increased instead of being reversed. The VSS signal circuit is supplied battery positive voltage through a resistor then monitored within the rear side door actuator control module. The VSS signal circuit is then pulsed to ground, or pulled low by the powertrain control module in relation to vehicle speed. The sliding door alarm will sound repeated short tones whenever the power sliding door system is turned on and the door is open while the transmission is out of park.
When the power sliding door system is on and manual operation of the power sliding door is detected the rear side door actuator control module activates the power assist feature. When the power assist is activated the power sliding door will continue to open or close without any further manual effort.
The power sliding doors may be operated using the Remote Keyless Entry System. The keyless entry transmitter will have one OPEN/CLOSE button with a van symbol on it for each power sliding door. The power sliding door ON/OFF switches in the overhead console must be in the ON position in order to operate the power sliding doors using the keyless entry transmitter. When a right hand power sliding door OPEN/CLOSE function is activated using a keyless entry transmitter the exterior lights will flash once indicating the RKE module has received the OPEN/CLOSE command. When activating a left hand power sliding door OPEN/CLOSE function with the keyless entry transmitter the exterior lights will not flash.
The left and right power sliding door systems operate as independent systems. The on-board diagnostic modes are entered and operate the same in both systems.
The power sliding door systems are capable of the following on-board diagnostic functions:
ā€¢ Diagnostic Mode 1: An audible signal indicates the diagnostic trouble codes stored by the rear side door actuator control module.
ā€¢ Diagnostic Mode 2: An audible signal indicates when inputs to the rear side door actuator control module are active.
ā€¢ Diagnostic Mode 3: Performs an output test of the sliding door unlatch actuator.
Entering On-Board Diagnostics
The on-board diagnostic modes can only be entered in a sequential order from modes 1-3.
ā€¢ Enter the right power sliding door system on-board diagnostics using the right B-pillar open/close switch and the right on/off switch in the overhead console.
ā€¢ Enter the left power sliding door system on-board diagnostics using the left B-pillar open/close switch and the left on/off switch in the overhead console.
1. Both power sliding doors must be closed and in the latched position.
2. Place the ignition switch in the OFF position.
3. Place the on/off switch in the overhead console to the OFF position.
4. Press and hold the B-pillar power sliding door open/close switch.
5. While holding the open/close switch, operate the on/off switch through 10 ON and OFF cycles within 10 seconds stopping in the on position.
6. The sliding door alarm will sound 1 long tone indicating diagnostic mode 1 is active.
Diagnostic Mode 1
Upon activating diagnostic mode 1, DTCs will begin to be signaled by the sliding door alarm. The DTCs are 2 digit codes and the codes are represented by the number of buzzes for each digit of the code number. For example a DTC 12 is represented with the following sequence: buzz, pause, buzz, buzz, long pause. Each DTC will be signaled 3 times before proceeding to the next DTC. Refer to Diagnostic Trouble Code (DTC) List . The DTCs will continue to be repeated in this manner until the on-board diagnostics are exited or mode 2 is entered. When exiting the on-board diagnostics all stored DTCs will be erased from the rear side door actuator control module memory.
3helpful
2001 Toyota Sienna r.h. sliding door ''rear latch switch'' location
To start, the noun "''rear latch switch'' is incorrect. It's actually called "Slide Door Lock". It's located on page BO-20 of the Toyota Repair Manual for the 2001 Sienna. There are two door locks on one sliding door. One in the front and one in the rear. Obviously, you want the one in the rear. The location for the "Slide Door Lock" (which also contains an electric switch) is in the rear of the sliding door located mid way up door. You can see (sliding door opened from the back) it without dissembling the door. And, the lock is made up of plastic (dirty white in color).
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
