Question about Dell Computers & Internet
Pin out specs for dell f200eu-00 d-0200adu00-201
Posted by Darren Arbouin on
Darren A.
    New Friend:
Both connectors as i need to jump & verify psu won't power up with meter
Posted on Aug 06, 2015
Dell m5110 laptop won't charge new battery and ac adapter is not recognized in bios
Try another AC cord/charger with the EXACT same specs as original. Is the battery a genuine Dell battery, if not return it? Some aftermarket laptop batteries don't play well with your computer, the pin-out connections aren't correct and MAY be a fire hazard.
Apr 06, 2013 | Dell Inspiron Computers & Internet
Does DELL Inspiron 6400 has a inbuilt microphone? If it does how to make it work?
I am sorry to say but, the 6400/E1505 does not have an internal mic. You need External. Sorry. Specs only show a MIC connection. I/O Ports IEEE 1394 4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors Flash Memory Slot - Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, xD CD type I/II, & IBM Microdrive through ExpressCard adapter Video: 15-pin monitor connector S-Video: 7-pin mini-DIN connector Audio jacks: Stereo headphones/speakers mini-connector (same as line-out), microphone mini-connector
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 09, 2010 | Dell Inspiron 6400 Notebook
What kind of processor does it have... I mean pins and or exact type of intel processor
here is a detail specs of that machine
GX280 SPECS
hope this is what your looking, and that it helps.
Mar 28, 2010 | Dell OptiPlex GX280 PC Desktop
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
34 pin FRONT PANEL insert locations.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
This link should open an html document from Dell, providing you with all the information you seek.
good luck
tony
May 20, 2009 | Dell OptiPlex GX270 PC Desktop
Dell Latitude D600 RAM
yes it will as long as you keep the speeds the same and the pin count on the ram the same
Nov 18, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 2650
Here are the specs of your RAM:
  • Module Size: 256MB
  • Package: 200-pin SODIMM
  • Feature: DDR PC2700
  • Specs: DDR PC2700 • CL=2.5 • Unbuffered • Non-parity • DDR333 • 2.5V • 32Meg x 64
  • MAX 512 MB
    Here is where I normally Buy RAM:
    http://www.crucial.com/store/listparts.aspx?model=Inspiron%202650%20Series
    May 20, 2008 | Dell Inspiron 2650 Notebook
    Computers & Internet Logo
    176 people viewed this question
    Lee Hodgson
    Lee Hodgson
    efs_perpends
    efs_perpends
    Michael Thomas
    Michael Thomas
