Question about Saniflo Plumbing
My saniflo tank is leaking from the lid.
The seal was cleaned and re-installed, but continued to leak. A new seal was installed and I still have the same issue, except now it won't leak until after about 20 cycles as opposed to just one with the previous seal.
Posted by Dave Pettie on
5 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
Posted on May 04, 2008
Anonymous
SOURCE: leaking from base/side seam of urn
I bought a new urn from ABTECParts USA.
Posted on May 10, 2008
Anonymous
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
thevacdudes
  • 37 Answers
SOURCE: clean water tank leaks
Your going to have to replace it again, good thing is they completely remodeled the new one.
Posted on Aug 29, 2009
tberan1
  • 523 Answers
SOURCE: I recently had a Saniflo unit replaced after 20
David,
I am not directly familiar with this unit but have worked with others. The bubbling sound at the end of the run does sound odd. My thoughts go towards venting of this discharge pipe; is this properly vented?
Thank you,
Tom
Posted on Sep 25, 2009
How do I stop the crankshaft rear main seal leaking.I have already installed a new seal, but there is still a leak.
If you didn't damage the seal during installation then there is probably an issue with the crankshaft being worn. However I would lean towards a damaged seal
Jul 26, 2016 | Alfa Romeo Cars & Trucks
Driver side axle leak
front or rear? axle.
movement where
in, out, left right , up or down,. or all?
its a 3D world post directions.
btw, most seals that leak are due to bad bearings allowing the shaft
to beat the seal to bloody death, fact. (Timken.com)
only 1 exception, but is not where you are.
Jan 21, 2014 | 2003 Toyota Celica
Replaced water pump seals twice on 06yz450 and they keep leaking
I would reccomend replacing both water pump shaft bearings and also the shaft if there is any sign of grooving on the shaft. Without looking at a diagram i am assuming that the water side of this bikes pump is a mechanical(ceramic) seal design . Sucessful replacement of these mechanical seals can be tricky. A few tips are: be certain that all case surface areas are clean with all old seal/sealing debris removed such as with sccotch brite. So that the seal will seat and seal properly in the case. NEVER allow your dirty/oily fingertips to touch either of the ceramic pieces of the seal in the contact area. Lubricate these ceramic pieces with a standard green type of coolant only upon assembly. Always use a regular green type of coolant in the system untill you are confident of the install and then change to another type if you are going to. Be aware that it is not uncommon for the mechanical(ceramic) type of seal to weep slightly during initial break in as the two halves seat to each other. This weepage should dissappear in a short period of running time.
Dec 30, 2012 | 2006 Yamaha yZ 450 F
Diverter valve leaks
I have experienced the same diverter motor leaking problems. I have the whirlpool gold with the diverter motor (w10155344). I bought the unit new 4 years ago. The fix is remove the the two screws that hold the diverter motor and pull the motor. You will find why its leaking is because the rubber seal was installed up side down from the factory. The seal and motor should have calcium and corrosion build up from all leaking. No need to buy new parts. Clean the rubber seal with CLR very carefully, as you will notice a deep groove that has a spring around the inner part, use a tooth pick to clean the corrosion out of the deep groove. After a thorough cleaning, apply thoroughly with vaseline for rubber velocity, be sure to wipe off excessive vaseline. The diverter motor can be cleaned by separating the clips with out breaking tabs that hold it together, be sure to clean the corrosion off the wire connection and the little board it connects to on motor. When installing the seal, slide it down the motor shaft with the deep groove face down it should slide into the lip at the bottom and seat nicely, be sure to clean that area as well with CLR. Install the motor, be sure to clean with CLR where the shaft goes into the hole. That took care of the problem for me. Thanks.
Nov 12, 2012 | Whirlpool Dishwashers
Samsung mold issues dishwasher DMT400
Unfortunatly there is nothing you can do except clean it out every couple days, the way it's designed the water sits there after a wash and has nowhere to go so it just festers and molds over time, I put myself on a regiment to clean it out once a week. It sucks but that's all you can do.
Sep 08, 2012 | Samsung DMT400RHS Builtin Dishwasher
Won't idle without choke on
check for vacuum leak and spark plug wires firing ordered. use a bottle of propane around the intake seal to check for leaks there (if you have a leak at the seal the engine will surge near the leak)
Jul 08, 2012 | 1997 kawasaki VN 1500 Vulcan Classic
Continuous loss of refrigerant in air conditioning system. A/C has been evacuated and tested with dye under pressure but no leaks are found (except my usually excellent mechanic says it might be under the...
Could be the evaporator, rare but possible. Double check the schrader valves on the high and low pressure lines, and the shut off valves on the lines going to and from the condensor, and the condensor itself. (common culprit) Also the front seal on the compressor if leaking will have oily residue all over. No offense but try a different mechanic. Sometimes a new set of eyes works wonders!! Your mechanic won't be offended. If he is, fire him.
Aug 24, 2011 | 2003 Mercury Grand Marquis
My 10 year old Sub-Zero refrigerator works very well except for two issues: 1. I continuously have from 1/2 to 1 inch of frost build up in the center of the back wall. I have cleaned the refrigerator...
Hello Teresa,
I'm going to address the main issue and that is the frost ball in the refrig. That is due to a leak of some of the refrigerant having leaked out causing the frost ball.A company could come out and recharge the refrigerant and that would work for a while till it leaked again. What it takes to fix it properly is to replce the coil in the refrig. then recharge the refrigerant. That typically cost around $1,200.00 but will stop it from leaking ,and avoid paying $200 to have it recharged every year or less.
Gene
Aug 12, 2011 | Sub-Zero 601R
Continuously running
Is the condenser clean and free of dust? If not clean it, that should help. Also make sure the door seals are in good shape and not torn or leaking. If that doesn't cure the issue you will need a new compressor module more than likely. At that point a new Fridge is a real option due to repair cost.
May 14, 2011 | Refrigerators
My toilet is turning on and off periodically. I replaced the flush value seal (red rubber ring), but it continues to leak. Is there a trick when replacing the seal?
Top and bottom seals:
It is best to replace both at once to assure the new seals are pliable and come together to form a water tight seal.
Replacing only one, the old seal is probably stiff or cracked and will not seal properly.
No secrete I am aware of except clean new and level parts.
Oct 04, 2009 | Mansfield Plumbing Products Home
Plumbing Logo
368 people viewed this question
Top Saniflo Plumbing Experts
Bill Johnson
Vernon Taylor
Tom Chichester
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
