Question about Kodak Easyshare M1020 10-inch Digital Frame new
Why is there no touch control on border?
Frame does not light up. powers up; will play videos audio and pictures. I transferred firmware from PC but can not install because I need to touch the frame to do so? What is the part that lights up?
Posted by t613531 on
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
  4. In the menu bar, select File ® Copy to.
  5. Select the frame source to which you are copying.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  7. Click Copy. Pictures are copied to your frame.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Posted on Dec 27, 2008
Anonymous
SOURCE: kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Posted on Dec 28, 2008
Anonymous
  • 75 Answers
SOURCE: how do I transfer pics from my computer to digital frame sv811
Connect the frame to you computer via the USB cable. Your computer should see the frame as a removeable storage device (new drive letter) if there's memory on the frame to store images. If not, then get a cheap memory card or USB key for $20 and put the images there.
Posted on Jan 11, 2009
Anonymous
SOURCE: Cannot play videos in Kodak SV811 photo frame
Finally solved this one. My Kodak Sv-811 Digital Frame would not play any videos UNTIL I decompressed them. .mov videos are compressed, usually with mpeg2 or mpeg4 or h.264 methods. In Quicktime Pro (or any video conversion able program) under video options, choose "photo-jpeg" or basically no compression. The file is 3 times as large but it will play!
Posted on Mar 20, 2009
Anonymous
  • 47 Answers
SOURCE: I can't transfer pictures from
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Posted on Jan 05, 2010
How was the msi on the 90's?
Go online to find experts that may guide you step by step.These menonline may show you how to fix your console just as an experienced repairmanwould fix it. Allthese errors can be fixed completely by you without the involvement of anyexternal agency. Disassembly 1.PS3 Disassembly 2. PS3 Controller Disassembly Fix Common Problems Fix to all update related problems 1. The Mystery of the Blinking PlayStation 3 2. The dirt on Blu-ray lens (and how to clean it) 3. PS3 Owners Report Blu-ray Problems After 1.5 Upgrade 4. PS3 Bluetooth Controller Issues 5. Playstation 3 HDMI Problem and Fix! 6. Display/Video Fixes 7. PS3 Error Codes (With related fix) 8. How to Change From HDMI > Composite Easier 9. PS3 3 Beep & Blinking Red Light Fix PS3 Modifications 1. PS3 3.5" SATA HDD Mod 2. Adding IR Remote Control to the Sony PS3 3. PS3 HDD Replacement Mini-Guide 4. USB Flash Memory, USB Hard Drive (External Use) Controller Modifications 1. PS3 Controller Light Mod 2. PS360: Microsoft Controller, Meet Sony Controller 3. PS3 Controller Light Mod 2 4. PS3 Controller Button Contacts, Add extra buttons to the PS3controller Other Modifications 1. Charging Station Headset Mod Blu-Ray 1. Decrypt Blu-Ray Movies with a PS3 WITHOUT keys 2. Blu-Ray Unique Volume Keys 3. Blu-Ray Media Links 4. Play BluRay movies without disk 5. Convert HD-DVD To Blu-ray (works On PS3), No Loss Of Quality Other Media/Video 1. Set up media servers for your PS3 2. Transfer files from PC to PS3 via WmP11/Nero (viaDLNA/MediaServers) 3. How to stream AVI files on PS3 via Tversity 4. Copy music/videos from your iPod to PS3 5. Getting your PS3 to recognize your External Hard Drive 6. How to create a PS3 HD-MPG from HD-TS (Best Result For Below 1.6FW) 7. How to install your game saves 8. Downloading PS3 Game Saves Audio 1. How to connect PS3 to PC speakers Networking 1. How to change from 'NAT type 3' to 'NAT type 2' 2. Make a Lag Switch 3. Who Needs SIMPLE DNS 4. Remote Play On-The-Go Playstation Network 1. PSN Game Sharing Instructions 2. How to download Japanese Demos/Create *** PSN account 3. Create Different Region PSN Accounts 4. View PS3 Store, Download Demos on your PC and install Demos To PS3 5. Play Online And Access Sony Store No Updating 6. View Playstation store on PC Firmware Modifications 1. PS3 Firmware Version Check Bypassed (Linux) 2. PS3 Firmware Version Check Bypassed (Windows) 3. Ettercap Windows 4. PS3 Demonstration Mode "Unlock" Code 5. Use SIMPLEDNS To Bypass The Firmware Check (Windows) 6. How to UPDATE your PS3 Linux 1. How to install Fedora Core 6 Linux for PS3 2. PS3 Linux - The void has been filled...Full install instructionsfor Fedora Core 5 3. PS3 Linux FAQ 4. GUI Kboot 5. Yellow Dog Linux Free Version 6. Yellow Dog Linux 5.0 Installation 7. Partitioning and readying your PS3 for Linux 8. Gentoo 9. Uninstalling Linux 10. Installing YDL+VLC+Mplayer+Snes9x 11. Installing Mplayer on PS3 12. Installing VLC player on PS3 13. Installing "Other OS" on PS3 14. How to get Wi-Fi to work with YDL 15. Set up a Linux UPnP media server w/PS3 support 16. Run Ubuntu Linux 7.04 (Feisty Fawn) on PS3 17. Ubuntu, Kubuntu, Xubuntu, and Edubuntu onto a PlayStation 3 18. Emulate WinXP in PS3 under Linux Downloads 1. Homebrew Loaders 2. Linux 3. Utilities 4. Firmware Updates 5. "Other OS" Bootable Homebrew 6. Drivers 7. Proof-Of-Concept Exploits 8. Game Saves PS2/PS1 on PS3 1. Do your PS2 games look too jaggy on the PS3? Here's a semi-fix... 2. PS3 SWAP to play PS2 and PSX Games! 3. How to play/install to play PS2 backups on PS3 Miscellaneous 1. PS3 Features 2. Finding RAM locations on resistance 3. PS3 Parental Controls How-to 5. PS3 BiOS Flash Diagram Rev 1.0 So,if you have experienced some of the errors in your console, it is not the endof your gaming days, you can fix it. There are many solutions out there if youare willing to do a little research. This guide most possibly willcontain the solution to the problem you have encountered.
Ps3 repair guide Goodluck, and happy gaming.
Feb 08, 2011 | MSI 1990 - 1996 for PlayStation 3
Tip
How to Watch iTunes M4V Video on HTC Smart phone
iTunes is an online media store of Apple Company, as you might know most of iTunes Movie Music has DRM (Digital Rights Management) protection which attempts to control use of digital media by preventing access. iTunes DRM movies are .m4v formats (m4v movie format is a standard file format for videos for iPod, iPhone, iPad developed by Apple), iTunes music is in M4A, AAC format.
So if you want to play iTunes music movie on HTC smart phones with freedom, a third party DRM removal software is necessary to strip DRM license from movie music, convert iTunes movie to HTC MP4, convert iTunes music to MP3.
M4V Converter is the ideal choice to transfer iTunes movie & music to HTC smart phone, as it can:
1. Remove DRM Protection from iTunes M4V, WMV, AAC, M4A, M4P
2.Convert iTunes DRM protected M4v to Mp4 and Convert M4A M4P AAC Music to HTC Droid Incredible Compatible formats MP4 AVI MP3 with best quality.
How to convert iTunes Music Movie on HTC with DRM Media Converter?
Here a tutorial shows you how to convert iTunes music video on Hero, Droid Eris,HTC Touch HD, Touch Pro2, T-mobile G1, Touch 3G,Magic, Dream, etc, make HTC phone a powerful integrated media player.
Step 1. Launch iTunes Music Movie files
Free download m4v converter, run it. And click" Add" button to import Protected M4V, WMV, AAC, M4A, M4P movie music files.
Step 2. Set output formats for HTC 3GP, MP4, WMV, MP3
Since HTC Touch phones play movie video of MP4, 3GP, click 'settings' to go to the output reference settings board showing like the picture bellow:
Click "Format Preset" to choose output format for your movie video, (generally MP4 is preferable with better picture quality), then the Bit Rate, Resolution, Aspect Ratio, and Frame Rate as well for output file quality and size. (You also click "default" to get the default Settings).
Tips: If you load audio files, click "Audio files to" to convert your AAC, M4A, M4P music files to mp3 formats.
Step 3. Convert and Transfer iTunes music movies to HTC
After setting formats, click 'start' button lower-right on the main window to start the conversion. Connect your HTC phone with PC through the USB cable, (external memory card works the same if you have), then you transfer iTunes media to HTC without limitation.
Now everything is finished, just enjoy your music and movies on HTC Droid, HTC Hero. And share the wonderful music and movie with your friends and family.
on Oct 21, 2010 | Computers & Internet
How do i play whats on the memory card nothing plays video only audio. or what do i need to convert it
First, make sure you have it on CARD (and not DISK), and on the "playback" (and not record) mode. Next, does the camera play back other video clips normally, but just not a specific clip ?
Does the selected video clip frame (index) shown on the LCD screen have a picture ? If not, i.e. it is blank (dark), then it is likely that no video was recorded (i.e. just the audio) when you were shooting that video clip.
If there is a picture (of the video clip frame index on the LCD screen) and only audio is playing, try downloading the clip (from the SD card) to your computer, or simply try to play the video on the SD card (inserted directly into your SD card reader on your computer, or via a USB SD card reader) and see if the video clip will play normally on your computer.
Jan 09, 2011 | Samsung SC-DC173 DVD Camcorder
Video OK but no audio when use SD card on photo frame COBY DP702
Audio is probably recorded with different codecs, one of which is unsupported by your frame.
Mar 23, 2017 | Coby DP-772 Digital Picture Frame
Pictures don't fill screen on Kodak M820 Digital picture frame
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to achieve an aspect ratio of 16:9, which results in noticeable distortion.
Jul 31, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Apr 02, 2009 | Kodak EasyShare SV811 (8858946) Digital...
What format does a .mov need to be converted to to play on a DF?
You can try these these file formats and compression rates:
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} File Format: MOV
File Format: AVI
You will have to look for a free video editing software and use it to be able to follow the above formats.
Mar 29, 2009 | Kodak 8" LCD Digital Photo Frame
How do i get my video to play....i am following the directions in the book....when i hit play...i get nothing....i am frustrated ....could someone let me know the step by step directions to get the video...
Make sure that you have the correct video format and compression. Video:
File Format: MOV
File Format: AVI
Music:
File Format: MP3
You will need to re-edit the video files you have for the frame to recognize it.
Feb 21, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Transferring video files to my pc
Loading video to PC should be the same as loading your pictures, although they will jist appear as the first frame of your video; looking like a picture. If you hover your mouse over the file you should see a file type as either .mpeg,.avi or mpeg4, you then right click and open with your preferred programme, be it your DVD player or Windows Media player.
Nov 30, 2006 | JVC Everio GZ-MC100 Memory Card Camcorder
Kodak Easyshare M1020 10-inch Digital Frame new Logo
53 people viewed this question
Top Kodak Video Cameras Experts
STEVE SPAM REMOVER
Bill Boyd
Are you a Kodak Video Camera Expert? Answer questions, earn points and help others
