Question about HP Office Equipment & Supplies
Why is My HP printer not connecting to Wi-fi?
When I want to connect my hp printer to wifi network of my hp laptop, even i ON the wifi but laptop can recognize the printer.
Posted by Martin Watson on
akshita garg
  • 3 Answers
Turn on your Wireless printer. You can use the touchscreen in the wireless printer to connect your wireless network.
On the touchscreen, press the right arrow key and press setup.
Select Network from setup menu.
Select Wireless Setup Wizard from Network menu, it will search for the wireless routers in the range.
Select your Network (SSID) from the list.
Enter the WEP/WPA Passphrase for the network and press Done
Press OK to confirm the settings
Press OK to print wireless report or Skip
Both wireless and wired computers on the network should now be able to browse to the printer and print to
Posted on May 16, 2020
John Walker
    Scholar:
  • 24 Answers
Steps to fix How To Connect HP Printer To Wifi Router:-
Open or Turn on your Wireless printer,
Press the right arrow key
And Click setup Choose Network from setup menu
Go to the Wireless Setup Wizard
And it will be search for the wireless routers in the range
Choose your Network (SSID)
If you don't know How to Connect HP Printer to Wifi Router click the link.
Annie Ross
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Fixing HP Printer Not Connecting To WiFi:
One of the simplest solution to fix this issue you can restarting you printer and Wi-Fi.
First of all check HP Printer connected to the network properly or not by using a wireless network.
After that, check your computer is connected to the Wi-Fi network or not.
If the user is not able to resolve the problem, they can simply reach out to printer offline helpline assistance to get a quick resolve all the issue related to you printer.
If you are still facing the problem now then you can read the troubleshoot guide tip for HP Printer not Connecting to Wi-fi.
Posted on Oct 01, 2019
Terry Hair
  • HP Master
  • 4,134 Answers
You sound as though you wish the printer to directly connect to the laptop via wi-fi. This is not usually the case in home networks. Most home networks use a wi-fi router to link all wi-fi components. This is because your laptop is not capable of handling the routing duties itself, nor is the printer (normally). The wi-fi router assigns the IP addresses that the devices use to communicate to the router and each other. That said, IF you ARE using a router, perhaps you are not entering the security code that the router needs to allow the device to attach to the network. If you are NOT using a router, then you still MIGHT be able to use the printer with the laptop if it has a "direct connect" capability. You would need to look at the printer documentation and instructions on how to set it up. Unfortunately, wi-fi isn't as simple as just turning it on an waiting for a connection to take place.
Posted on Aug 05, 2015
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
My laptop and HP Deskjet 3510 All-in-one printer are on wi-fi networked to my wi-fi router. My problem is that when my laptop is connected to the internet my laptop is not able to communicate with my HP...
Okay... Sound to me like the DHCP Server in your router is off..
Well, do this or have your technician login to your Router admin page ( by typing 192.168.0.1 or 192.168.1.1, (or something similar depending on the brand and make of the router) into your browser and hitting enter) and either make sure Lan side DHCP server is on, or leave it off and just assign different static local IP's to each of your network devices ( e.g. 192.168.1.10 for you laptop and 192.168.1.11 for your printer). I think that will solve your problem if its related to an IP conflict.
Hope this Solves your problem. :)
Jan 07, 2014 | HP Deskjet 3510 e-All-in-One Printer
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
I am not able to connect to the Wi-fi network in my area from my HP 6535B laptop. I am able to connect using another laptop on which there is specific button for wi-fi but from HP there seems to be...
"Wireless LAN" is the same as wifi. The HP 6535b does come shipped with wifi by default. The wifi can be turned on an off with a button on the laptop. The button looks like a typical wifi symbol (or a palm tree) as is located on the top panel above the keyboard, just to the left of the HP logo. If it is turned on it will be blue, if it's off it will be orange. As long as that is on you should be able to see any wifi networks in your area. If you can see the network but can't connect (even if you type in the right key) the issue may be that the wifi network is encrypted with WPA2 and you don't have the proper Windows patch installed. If you have Windows XP you'll need service pack 3 or the WPA2 patch from Microsfot (google "KB893357" and it's the first link).
Aug 30, 2010 | HP 6535B Notebook Turion X2 Mobile RM-70...
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
Wi fi
Could you make sure that wifi switch is turned on.
This will be physicall button on the laptop of function keys combination that enables wifi.
If wifi switch is on you should be able to see wifi networks in range. IF you see networks but can not connect this will be network security issue. MAke sure that wireless network router is properly setup and security key you enter is correct
Jun 08, 2009 | Compaq Presario 700 470024-192 Notebook
Print from laptop without using router to lexmark 6600 wifi printer
only if you get a wi fi access point and have a switch to connect the wi fi access point to but then you would have issues with NAT ( Network Address Translation ) which is used to be able to connect many computers to the internet through one internet connection.
Apr 30, 2009 | Office Equipment & Supplies
HP 6710b , wifi activate button not work...no light on
click the link here, and confirm it helped you solve the wi-fi problem on your laptop, if not then i'll provide another workaround.
Sep 21, 2008 | HP Smart Buy Notebook
203 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
