Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Frigidaire gallery washer smoking and not spinning
Smoking and not spinning. clothes still wet after spin cycle.
Posted by Suzy Streed on
Bob L
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 413 Answers
Sounds like you either have something in the pump or maybe the belt is slipping on the pulley.
Posted on Aug 05, 2015
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Frigidaire Gallery washer won't produce final high spin
Hey friend, thank you for your post!
I see that your Frigidaire washer, FWT449GFS2 is not entering the final high spin cycle. It is possible that you could have a defective motor or timer. Since it could be any one of these underlying issues I would recommend you having a professional come out to the home for the repair of your washer. -Matt
2answers
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Drum is loose in machine and swings forward and back. Clothes are still very wet after final spin.
the rear struts have come loose and need re tension this will cause the barrel to come loose due to the barrel not being centered it will not spin at full cycle vortex and leave the cloths some what wet you need to take the top and back covers off and re tension the struts and make sure all 4 springs are well attached..
best of luck
merry christmas
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
2answers
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
2helpful
2answers
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Open Questions:
See all Frigidaire Gallery GLWS1339EC Top Load Washer Questions
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
