SOURCE: what is the average life expectancy for a 2006
First thing you should do is ensure that the battery connections are tight on both ends if you can reach them the negative cable will go to a frame or engine ground and the positive cable should go to the starter maybe via a boosting post, if that doesn't work then remove the battery cables and clean the connections with a terminal brush. Corrosion on the terminals can cause poor performance of the starting system, make sure you do a good job and clean both the battery and the cars terminals or the symptom will still exist. From your description (no battery light after starting indicating a charging problem) if this doesn't solve your problem then you will need a new battery (Try charging the battery first it may work at first but if it happens again the battery is pooched or your locat parts store should be able to load test your battery to tell for sure if it is). Make sure that you have the codes to enter into your radio before you disconnect the battery as the honda's need this every time the battery is disconected. If you don't have it stop by your dealerships service department with your registration and they will be able to quicky run your serial number through Honda online and get you your radio code.
