Question about Cisco 7941G-GE IP Phone
I need to modify the settings of my cisco ip phone 7941
I bought a cisco ip phone 7941G from ebay. i can not have access to the settings. i need to have access to the network configuration i can't. please help me
Posted by Letage Dany on
Zaid Mohammad
    New Friend:
  • 29 Answers
Complete these steps:
  1. Unplug the power cable from the phone, and then plug in the cable again.
  2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. ...
  3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
Posted on Sep 16, 2015
5 Related Answers
Anonymous
SOURCE: Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Posted on Jul 12, 2007
Anonymous
  • 58 Answers
SOURCE: Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Posted on Mar 21, 2008
Anonymous
  • 48 Answers
SOURCE: CISCO 7941 IP PHONE disconnect you out after certain time
Unfortunately this is a very common problem with Cisco's IP Phones. It can be caused by either a faulty hookswitch or a damaged jack. Both of these problems can be remedied by contacting IdacomUSA.
Posted on May 13, 2009
Anonymous
  • 121 Answers
SOURCE: CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Posted on Feb 19, 2010
Anonymous
SOURCE: Can I use a CISCO IP 7941 phone, that has been on
you cannot connect these phones to a home phone line they can only be connected to a network, and you will eather need to load the SIP firmware on the phone and have a SIP provider or use a call centre manager such as Cisco or asterisk, but these phone require a Ethernet connection they cannot be plugged into a home line. (They also require internet access to make calls and there is a little work involved in getting one running.).
Posted on Jun 16, 2010
I cant test my 7941g because i keep getting a small bullseye on the bottom left corner of the screen
Your phone is trying to connect to a TFTP server address to download a firmware and/or config file update. You need to figure out what IP address it is trying to connect to (You may have to use wireshark or another packet sniffer to determine this).
Once you know the IP it is trying to connect to, you'll need to set up a small network with a TFTP server running on that same address, and feed the phone a firmware update and/or config file. It will likely not fully boot unless it gets a firmware update.
Cisco Phone 48V Power Supply
Dec 05, 2012 | Cisco 7941G IP Phone
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
When I plug the 7941 cisco phone up to our network on a POE switch, it responds with the message "Ethernet Disconnected", but when we plug another Cisco 7941 phone to the same line it works perfectly... We...
I would check your duplex settings. Often, if you hard code the duplex settings or have a mis-match; one end may not talk properly. Also, have you tested the wiring? Do you know the ethernet is okay for sure? TechRx, Inc. - techrxgb.com
May 12, 2010 | Cisco 7941G-GE IP Phone
Jan 07, 2010 | Cisco 7941G IP Phone
Can I hook a 1131ag LWAP directly to a 7941g?
If the 7941g is the cisco cp-7941g ip phone then no you can not since the ip phone only has ethernet connections and the airap1131agak has only wireless connections on it as it is a wireless access point, so you will need a wireless router or something similar to get the wireless to ethernet cable.
Oct 29, 2009 | Cisco Aironet 1131AG (AIRAP1131AGAK)...
Apr 06, 2009 | Cisco 7941G-GE IP Phone
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Oct 28, 2008 | Jabra T5330 Wireless Headset
CP 7941G issue
Try configuring CCM IP address either trough DHCP parameter, or Network configuration on the phone.
Oct 08, 2008 | Cisco 7941G-GE IP Phone
Jul 12, 2007 | Cisco 7941G-GE IP Phone
Cisco 7941G-GE IP Phone Logo
694 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
