Televison & Video Logo
jhun ilagan Posted on Aug 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the volts outputs of power supply? - Televison & Video
Sp Gupta
Level 3:
  • Televison & ... Master 727 Answers
  • Posted on Aug 04, 2015
Sp Gupta
Level 3:
Answers
727
Questions
5
Helped
144655
Points
3137
Hi Jhun,
As a general rule as soon as you switch on the TV, the power supply must produce stand by (sb) 5V or 3.5V as per the TV's design. Next, when you give power on command, the power supply should produce power on 5V or 3.5V, 12V and 24V or some other voltages as per the TV's design. All this is printed on the power supply pcb in most TV sets. I hope this helps.
  • Sp Gupta Aug 05, 2015
    Thanks Jhun. Where are you from?
Samsung plasma hp-r4272c, i dont have VS volt output on main power supply board
Just replace the main power supply board if there is no vs voltage output.
1helpful
How to get a symmetric DC power supply : i.e +18 Volts -18 Volts and ground from this kenwood power supply PDS36-20
You can't do that because it's not a split supply. There's just a single output referenced to ground, so all you can get is one voltage at whatever you select from 0 to 36 volts.
1helpful
Ultra 750 watt power supply ,+12 dc volt output showing ac component of 1.5 to 2.7 volts on new unused ps
Is this with or without a load?
There is always some ripple on the DC output of a switching mode power supply, and the less the load, the greater the ripple.
Measure the power supply under full load, that's the real test!
It wont get power. how do i fix it?
check the power supply output there should be 5 volts on the output this turns on the main board if there is no 5 volts then the power supply is at fault also look for open capacitors on the power supply this can also be a major problem causing the tv to not power up
2answers
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
1helpful
How do I check my bestec atx-250-12e power supply with volt meter
It's hard to do with a volt meter. What you would be better off doing is either ordering a cheap power supply tester online, and test yourself with that, or take out the power supply and take it to your local pc repair shop and ask them to check it for you. There are 12V outputs, 5V outputs and 3.5V outputs, and any of them could be bad, so that is why I say using a voltmeter is harder than using an actual power supply tester.
Let me know if this solves your problem.
Lambda ews600-18 voltage goes down.
there is a short circuit protection and overoad protection to smps so o/p capacitor may short or secondary diode may short .so check voltage at primary when switched off after 33seconds whether switching process is going or not for that check dc volt at i/p capacitor then check volt at collector of transistor if metr shows 1digit then switching is going if not then meter shows full dc volt check component near about that
Output voltage
Hello rcgibson, output of charger for (if this is correct 'Roadmate 800 GPS unit) AC wall power supply or 12/24 volt DC is 5 volt at 455 milliamp.
16helpful
Power supply
if you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
