Question about Vizio E470VL 47 in. HD-Ready LCD TV
Hi Robert,
This appears to be case of dirty ribbon and connector between the TCON board and the LCD panel.The ribbon or flat cable and its connector on the defective side between the TCON and the panel has to be cleaned thoroughly. If you can not do it yourself, any good tv Tech. should be able to do it for you.
Good luck.
Posted on Aug 04, 2015
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
SOURCE: half of screen is green, split down the middle
I never repair Vizio but I am sure this is the cause if this occurs on all video sources; WiI, TV tuner, etc.
LCD panel has 2 flat cables attached to the glass OR the board that attaches to the glass.
remove and reinsert this cable. Just know that if you open the TV you will probably see these cable easily....they will be at the upper middle portion of the back of the TV(inside of course)
There is 1 cable for the left side of the picture and another cable for the right. If the right becomes loose it affect right side of pictur and left cable left side.
Posted on Jul 10, 2009
SOURCE: TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Posted on Jan 09, 2014
Feb 02, 2018 | Televison & Video
May 12, 2013 | Dell Inspiron 1545 Notebook
Jul 05, 2011 | RCA R61WH76 61" HDTV
Apr 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Jul 12, 2009 | Dell Inspiron 1525 Laptop
May 11, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Apr 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Nov 24, 2008 | Hitachi 53SWX12B 53" Rear Projection...
Dec 17, 2013 | Vizio E470VL 47 in. HD-Ready LCD TV
95 people viewed this question
