Question about Furniture
Fan runs control panel lights up but cooler doesn't cool. Not sure if compressor is running or not. What are the most likely reason for no cooling. Please.
Posted by Tom French on
On-Time Appliance
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
This video is about a Danby wine cooler. But they all work pretty much the same way.
Posted on Aug 03, 2015
Barely cool, fan running and one tubing by compressor warm and one cool on and the cool
Is fan inside the freezer running with the light switch pressed in? To confirm a Freon on a refrigerator that still cools yet not well remove the rear panel inside the back of the freezer APPLIANCE911
Apr 17, 2016 | Refrigerators
Fan runs, control panel lights up compressor not running unit not cooling. Any ideas as to why compressor not running?
could be a start run capacitor failed
I suggest that you get a fridge technician to check ti out first as a compressor is generally more expensive than a new unit.
Aug 03, 2015 | Furniture
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
I am a different person with the same problem the compressor kicks on ,the light is on but it doesnt get cold it does seem like the fan at the top isnt working the one in the middle is thank you
The compressor is running, that is a good sign. If you notice any cooling that is not a good sign. Even with the fan not running , the evaporator should have produce some cooling. Could it be that you are a condenser fan running? well, the compressor makes a distinct sound when it runs and you need to confirm that is running and not just the condenser fan.
Firstly- If you confirm that the condenser fan is running; that is, if there is one, that is good. Secondly- Check and confirm that the compressor is running Thirdly- If there is an evaporator fan inside the unit, check and confirm that is running.
If all checks okay and there is no cooling, the refrigerant might have escaped through a leak, and there will not be any cooling. You can extrapolate from my troubleshooting steps to diagnose the wine cooler problem.
Good luck
Appliancewiz
Jacques
Dec 27, 2010 | Danby DWC257BL Wine Cooler
The wine cooler light works but it does not cool.
so the light tell us that it has power . you need to ck the fan underneath in back and make sure it is running and feel the compressor it runs when the fan does . and you may nees gas in the unit . . so ck the fans / then the compressor see if hot or can you feel it running and then the refergent . and the thermostat down in front . andy of these could cause the no cool problem. mm hope this has helped ..feed back pls ..
Nov 25, 2010 | GE ZDW24Y Wine Cooler
Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Emerson (025806803716) Wine Cooler
Stuck at 77 degrees!
Hi
Do not assume the problem is related to the compressor or the sealed, hermetic system; these types of problems happen only rarely. Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the unit should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the unit are both set to cool.
3) Listen for the compressor fan, where the compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the unit will offer very little cooling or none at all.
hope you will be helpfull..
Thanks for contacting fixya.com
Sep 10, 2009 | Cuisinart CWC-1200 Wine Cooler
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Furniture Logo
671 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
