I am using GV-650 in my shop...how can i connect it in network..and also how can i use it from home to see the camera...I am using GV-650 in my shop...how can i connect it in network..and also how can i use it from home to see the camera...
You can't post conmments that contain an email address.
Update your drivers to run on the new OS if the drivers are unavailable try running the program in Compatibility Mode Right click on the icon on your desktop or from 'All Programs' - select 'Properties' Select the Compatibility tab Select Compatibility Mode Use the dropbox to show the OS Click OK Restart your computer
Okay - try going into the software directory and delete the files maked .db there should be one for each camera. Then start the software and try it again.
This problem could be because of the GV card version not compitable with GV main systems software you install please check the hardware version of the GV card and compare for compatibility. East way out downgrade to lower version of software. for example if you have version 8.1 install then install version 7.0 or something like that.
You require Geo codec's. that is software to play that rare type of video format on your computer. just Google geoivion codecs or load them from your geovision software disk.
This PC has a ATI motherboard chipset, which is incompatible with GeoVision. GeoVision does not work with ATI or Via motherboard chipsets. ATI graphics cards are not an issue.
