Question about Planar Computers & Internet
Does the Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor" Have a microphone"
Posted by Rich on
burbil
    New Friend:
  • 26 Answers
No, there is no microphone listed in the specs, just integrated speakers
Posted on Aug 03, 2015
I have a Planar 1910(Black) LCD from a friend. It first had a problem where it would show no display but the power LED would flash green to orange. I fixed the problem by reseting it. Now that the display...
It has white screen becuase it may not be getting the 5vdc from the logic board to the T-CON board or the board has blown fuse.
Please see http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Also look to see if power supply/logic bd had any bad caps also.
Aug 14, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
Monitor control panel comes up for no apparent reason. Begins to rotate between options without any user input. If I hit the power button, the rotation stops, and the monitor remains on. Have already reset...
This sounds like a problem with one or more of the buttons on the monitor itself being stuck on, or a fault in the circuitry connected with the buttons.
Check for grit etc. in the buttons, maybe try cleaning with a soft brush while unplugged from power.
Apr 11, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
My Planar PL1910M monitor will not show pictures on the monitor. All connections were checked and power is going to the unit. The power button stays green typically but on occasion will flash yellow. This...
first of all the problem is not with the monitor...
its probably a corrupted BIOS
(basic i/p o/p systems) its the chip in the motherboard which stores the configuration of your system...
one way to get around this is to,
open the case of your CPU
then on the motherboard there will be a small battery, which is called the CMOS battery ...
take out the battery from its slot...
after a minute put it back in the slot..
now you shold be able to work fine because the BIOS loads with default setting...
if this one works please give a vote
Feb 28, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
Monitor say Input not supported. What does this
Your graphics card is set to a resolution of refresh rate that your monitor cannot handle, This can sometimes be one of the normal settings - there is not much you can do. Each monitor has a native resolution which the monitor should always be set at yours is:- 1280X1024
Nov 03, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
No sound - looks like I need some sort of cable as the blue plugin in the back is the same as blue plugin in back of computer?
Yes, if your monitor has built in speakers, you will still need a cable running from your computer to your monitor.
Jun 30, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Planar 19'' model #PE1901BK---REMOVE THE BACK PANEL.
Check to see if the various connectors are mounted on a separate subpanel that is independent of the back cover or if you must perhaps remove some of the protruding connector hardware. The 'F' connectors (the threaded coaxial type for cable or antenna input) for example, may have a fairly large diameter (but thin) nut securing them.
Oct 26, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Buzzing sound coming from monitor speakers
Check your leads, chances are it's a faulty/dodgy lead coming from your macbook to the system.
Jan 14, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Computers & Internet Logo
85 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
C. David Graves
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
