Question about Brother IntelliFAX 4100 Laser Fax
Brother 4100 Fax Machine / Incoming Faxes
We are not sure how to set up our Brother 4100 Fax Machine to where incoming faxes post the time and date stamp that is programed in the fax machine. This information is very important for our business. Currently it will just print whatever the person that is faxing something over information. But most of the time that is not correct so we want to also include on this incoming fax what our time and date stamp is as well. Does anybody know if this machine is capable of doing this?
Posted by missc200 on
  • Anonymous Mar 18, 2014
    how do I change the time from am to pm on a brother fax machine
CheckitRight
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,363 Answers
Need to program to date stamp incoming emails
Hi Deanna, unfortunately it is not possible on this unit to have the date and time stamped as that is produced by the senders machine, this feature is referred to as the station ID on your brother machine.
Mar 26, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
No incoming fax tone
Sounds like it's not set to auto-answer faxes. Do you have the manual so you can see how to check that setting? If not, I can try to find it.
Aug 30, 2007 | Brother IntelliFAX 4100 Laser Fax
PROBLEMS WITH CLARITY OF INCOMING FAXES /BLACK STREAKS DOWN ENTIRE PAGE/VERY HARD TO READ SOME OF THE INCOMING FAXES.RECENTLY REPLACED DRUM AND TONER/WHAT WOULD BE CAUSING THIS PROBLEM?
First, make a copy of something to determine if your machine is at fault.
Move the blue slider on the drum cartridge back and forth 10 times.
Oct 01, 2009 | Brother IntelliFAX 4100 Laser Fax
Incoming faxes always go over to a 2nd page - just a small amount - but it waste that next sheet - how can I make it fit better - or shrink the page 5% to fit better? Dean
Printing a Reduced Incoming Document
Your machine can reduce the size of an incoming fax to fit the size of the paper
in your machine. Select ON to turn on this feature.
After you connect Cassette #2, you can turn on Automatic Reduction for each
cassette. (See Turning on Cassette #2 (Option for FAX-4100 and FAX-4750e), Page
4-1)
1 Press Menu, 2, 1, 5.
2 If you have the optional Cassette #2,
press or to select CASSETTE #1
or CASSETTE #2, and then press Set.
3 Use or to select ON (or OFF), and
then press Set.
4 Press Stop/Exit.
If you send faxes from a computer on the same phone line and your Brother
machine intercepts them, set Easy Receive to OFF.
Cassette #2 can be purchased.
Aug 24, 2009 | Office Equipment & Supplies
Our fax will not pickup incoming faxes
The mode is correct. You can check the rings to answer setting. Default is 4 rings. If your phone line is just for the fax try setting rings to 1. Sometimes sending fax machines go into redial before the 4th ring.
Also, sometimes unplugging the power for 10 seconds will clear any memory that may have locked up the machine.
Hope this helps.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Our Brother Intellifax 3800 will go to sleep and ignore attempts to send or receive faxes. It will take a docment into memory and go to sleep and not send it or the phone will ring with an incoming fax and...
i don't have the owners manual handy, but i'm quite sure you can disable the sleep mode by pressing a couples of buttons on control panel. that procedure is in your owners manual on the same page as setting sleep time.
hth,
razors
Mar 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
CANCELLING INCOMING FAXES
Unplug the phone line and unplug the fax machine. Then clear the memory if it starts printing out again.
Mar 07, 2008 | Brother IntelliFAX 4100 Laser Fax
Can't receive outgoing faxes, but CAN receive in-house faxes
MAKE SURE YOUR PHONE LINE IS PLUGED INTO THE JACK ON THE FAX THAT IS MARKED LINE ALSO CHECK THAT THE MODE KEY IS SET TO FAX
Oct 23, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
690 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
