Hello Lani, thank you for your post!
Based off the information you have provided your oven door is locked and you need assistance to open it up. On your control panel you should see a cancel button, if you hold that button down it should release your door. If that does not work I would recommend disconnecting power from your range for at least ten minutes. This should help clear any error within your range or control panel. If that does not correct your issue you may need to have an electrical part replaced. I would suggest having a professional out to provide a proper diagnosis and repair. This will help you avoid any unnecessary part purchases as well as future issues. -Matt
