Support - RCA Television
www.rca4tv.com/support/faqs.asp
DVD COMBO TV ... Similar to how a computer can lock-up and then you have to re-boot, TVs sometimes have problems that you can fix by resetting, or rebooting ...
SOURCE: how do we take the stand off of a 26" Insignia flat screen tv/dvd
Look on the back - there are screws holding the stand mount
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
