Question about Danby DFF1144W Top Freezer Refrigerator
Disable auto defrost - Danby DFF1144W Top Freezer Refrigerator
Posted by Robert MacPherson on
  • Luke Smith
    Luke Smith Feb 16, 2017
    Hey Robert, I hope you've had some luck trying to figure out how to disable your freezer's auto defrost feature. I am definitely not an appliance expert, but I would bet there are plenty of people in your area who could help you out. I would probably start with a google search for appliance repair, but that's just me. http://www.freezerandfridgerepairs.com.a...
Claude Kayser
    Top Expert:
  • Danby Master
  • 9,098 Answers
Freezer Repair Help - Free troubleshooting and videos ...
www.repairclinic.com/RepairHelp/Freezer-Repair-Help
This video provides information on how a freezer works and offers troubleshooting... Frigidaire Upright Freezer Disassembly - Freezer Repair Help · Repairing a ...
Posted on Aug 03, 2015
Larry, I want to disable the auto defrost or frost free function on my 20cu ft kenmore freezer
You could disconnect the power to the defrost timer or the heating element itself. I suspect that accessing the timer would be much easier that the heater - but I don't know which model fridge you have.
Jul 20, 2015 | Kenmore Refrigerators
FRIG NOT COOLING - FREEZER IS FINE
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 27, 2011 | Samsung Refrigerators
I have a whirlpool side by side fridge/freezer model 6ED22PKXFW00 and every time the auto defrost kicks in it trips out the circuit on my power board. I'm chasing an electrical drawing to disconnect the...
the reason for the power trip is your element use to defrost the freezer is blown and earthing out hense when it goes into auto defrost it will trip the main power
simple repair replace the defrost element
best of luck merry christmas
please rember to rank this advice
Dec 07, 2010 | Whirlpool Refrigerators
Ice build up in refrigerator. Not cooling
Fault in the auto defrost section. shut off the fridge and defrost , check onthe thermostat , faulty lines wire breaks due to frost. if not trace the wires to the auto defrost timer. check the heater continuity/resistance. When the fridge is started back check the timer and see if the auto defrost works. If not check thermostat and the timerr contacts or if it is running. if not replace.
Aug 28, 2010 | Refrigerators
Mobile phone unlocking codes
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Jun 08, 2010 | Cell Phones
Center Column is getting hot
Generally that means your auto defroster system is defective. It could be a simple switch/sensor. See if you can find a switch to turn off the AUTO DEFROSTER and see if that solves it. If it does, then you have a sensor problem. If it does not, then you might have a short in the system and it would be advisable to have a certified technican look at your unit. If it is a short and it is in the walls, then you are probably S.O.L and might have to disable the defroster and live with it and just be required to manually defrost your refer unit it truly dies. Reason being, if it is in the walls, it is cost prohibative to open the walls and repair a refers wiring, tubes and other components in the foam and such. Sorry for the tough news. Lets hope the techincan you have come out finds a cheap easy fix for you.
Kindly,
Dec 10, 2009 | Whirlpool GC5SHEXN Side by Side...
Is there a way to disable the frost-free feature on amana freezer
If you disable the frost free feature you will have to defrost every 10 days.
But, yes,it can be done.
Aug 05, 2009 | Kenmore 53542 / 53544 Side by Side...
HOW TO BYPASS
If the refrigerator is not icing up it could be the defrost thermostat making the defrost cycle initiate every time the defrost timer makes defrost available. I do not recommend by-passing the defrost cycle, have the switch checked and replaced if needed.
May 26, 2009 | Frigidaire Freezers
Need unlocking code of Samsung SCH- w339
hi i am using rel connection can i buy sch-w339 and use the phone for rel connection with unlocking code given by u
Dec 31, 2008 | Cell Phones
Fridge fan noise
Du musst den Abtausensor erneuern, ((Gelbes Kabel ))
Jun 03, 2008 | Samsung RS2534 Side by Side Refrigerator
Danby DFF1144W Top Freezer Refrigerator Logo
581 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
