Proscan 7-Inch Android Internet Tablet, Capacitive Touch Screen, Android 4.1 Jelly Bean, with Included Case and Keyboard Logo
A
Anonymous Posted on Aug 02, 2015
My proscan tablet is don't know password. trying to unlock . please help. yes press reset nothing
rostit
Level 3:
  • Proscan Master 746 Answers
  • Posted on Aug 02, 2015
rostit
Proscan Master
Level 3:
Answers
746
Questions
0
Helped
202002
Points
2851
Try this hard reset. You will lose all data. the device will be like it was new. Its your only option. Factory Reset on Proscan PLT7223G or Tablet Vol Rocker
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
How do I decrypt a storage password for a PLT7100G(DG)
try a factory reset
1. shutdown the phone
2. hold volume up button and press the power button
3. when manufacturer logo come leave the power button but keep volume up button to get to recovery mode
4. in recovery mode use volume up/down button to navigate and the power button to select
5. choose WIPE DATA / FACTORY RESET than select YES .... wait a moment then select WIPE CACHE PARTITION
6. finale step select REBOOT
keep in your mind all data in the phone will be erased
How to unlock proscan android tablet plt8015-k-b
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
Tryin g to unlock tablet, I didnt add a password to the main page and its requesting a password
Have you tried the reset via the pinhole with a paper clip yet?
And then trying a full factory reset .
How do i unlock a proscan plt8816k if i dont remeber the email and password?
Your problem doesn't make sense. You cannot try the password too often. Try a factory/hard reset.
Google search "reset android tablet"
I put my my proscan 4.1 tablet into talk back mode and now it jut would not let me unlock the password. What do I do? B.T.W. it's the kid of password when you use a keypad.
At start up, press the power button and the volume UP button at the same time, then release at the same time. The recovery menu should appear when you release the buttons. Sometimes it can be a little finicky. Try to make sure you're pressing the buttons exactly at the same time. I think it can work as well if you press the volume UP button first, and then the power button immediately after, holding both down at the same time, then releasing.
From the recovery menu you can restore the tablet to new, then reset a new password. You will have to reload all your apps and all existing data will be erased.
I hope this hleps.
j
I have a Proscan PLT7223GK6 Android tablet, and I can't seem to get it unlocked. I am not using a pattern to unlock the device. Is there a way to reset the password without resetting the whole device?
Tablet PLT7223GK6-B ((Solution)) Funtional
1. Power off the Tablet.
2. Press and hold the Volume Down button of the device, then a press and hold the Power button.
3- when you leave proscan logo, you can release the botton
4- leaving snowman Android, Press and hold the Volume up button, then Press and hold the power button.
Until you see the menu.
up / down- escojen the option to make
power button- the selecionan
5- Wipe Data / Factory Reset
6- Reboot System now
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
