HP Photosmart C7250 All-In-One Thermal Printer Logo
T
Tony Evans Posted on Aug 02, 2015
Window on my printer keeps telling that I cannot print or copy & mentions error Oxco5doo82 & suggests to shut off power &restart & then I go thyrough the same procedure again
Dave Moffat
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Aug 02, 2015
Dave Moffat
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
5554
Points
45
1 Remove all cartridges.
2 Put cartridges back in.
Should be OK then
Mp c5502. Why does it keep displaying 'door open' even though it's closed?
Sometimes Door open error shows in printer even if it is closed .
Follow This steps to Fix Open Door Error Message:-
*Close the cartridge access door completely.
*Check the cartridge door for obstruction.
*Reset the Printer
*Restart the Print Spool Device.
*Restart the computer.Restart the Printer.And If you are using Brother Printer And You Encounter With Brother Printer In Error State Windows 10 Issue then Read The Blog I Am Mentioning above.
3answers
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
Goodluck,
Please don't forget to rate the solution.
My envy 4500 series is in error state and wont print,what can I do.
The Brother Printer In Error State Windows 10 is an error normally displayed when the printer is jammed, low in paper or ink, the top is open, or the printer is not connected properly etc. Here some relevant answers to fix this error. the printer is in an error state, unable to print documents or unable to connect to the printer? Here every possible solution to fix Printer in Error State or Offline on Windows 10. Several windows users report After New windows 10 fall creators update or Install the latest updates attached printers stopped working or getting Printer in Error State problem.
4 Easy steps that resolve Brother Printer In Error State Windows 10 Easily.
1. Check the Printer Joint: Check the power cables attached to the wall outlets and also the USB wires connected to the PC.
2. Restart the Printer and Computer: Turn OFF and ON the Brother Printer.
3. Check the ink levels: In case the Brother Printer ink is very low or coming to an end then kindly replace the toner.
4. Check Paper jams: Look out for stuck papers inside the Brother Printer.
If you want a full blog about Brother Printer In Error State Windows 10 check this blog which is mentioned. Just follow the steps which are mention on the blog to fix the Brother Printer In Error State Windows 10. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER which is mentioned in our BLOG.
2answers
Printer offline
Brother printers are cost-effective printers that give up to mark printing. In addition to printing, a user can copy and scan from the printer works into a USB and also a wireless connection.
In Brother printers, offline failure happens once in a while. This writeup tells about the reasons for this error along with their solutions. We have read 'how to fix why is Brother printer offline issue' for both Windows and Mac operating systems.
Reasons that cause this irritating Brother Printer Offline Windows 10:-
1.Paper jam error.
2.Ink toner blockage.
3.Error in the network connection between your computer and printer.
4.Wicked or outdated printer drivers.
5. If the printers ' use offline mode' is selected, it may also show the offline error.
6.Wrong printer settings.
Just follow the steps which are mention on the blog to fix the Brother Printer Offline Windows 10. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER in our BLOG.
2helpful
2answers
Every time I try to watch any online videos such as youtube, hulu, or even netflix, my computer restarts and its always at random time into whichever video im watching, sometimes it may not happen, but If...
Check the Windows error logs. You did not mention what OS you have (!!). Look under admininstrative tools >> Event viewer, in the control panel. This will give you clues as to what is failing.
I suggest that you immediately extract the hard drive and backup all of your data. Something big is going on and system failure is coming soon.
All the lights are blinking at once on my printer there's an error symbol in the window that tells you how many copies its making and when i push cancel it won't cancel it also wont print or scan from my...
take out all the paper and it wont print further then shut it down let it wait 10 seconds and open the tray and toner compartment to make sure all papers are out. Now restart the printer and to a cleaning and test page. You should be fine.
Good LuckPlease rate me good
1helpful
My hp photosmart c3180 printer keep saying check paper when im trying to print or copy something.
please disconnect the power cable from the wall outlet then press and hold the power bottoum for 20-30 sec then restart
and try to print test page and copy if still it not work then follow this instrution mention from the below URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652863&cc=us&lc=en&dlc=en&product=1146331
if still your problem is not resolved then contact HP toll free number 1800-474-6836.they will replace your printer if its under warranty.
thanks
regards
Hamid
I/O error when trying to scan. Used to work OK
Good day Sir,
These are my suggested solutions.
  • There ma be a copying or printing job in progress. When the job is complete, try your job again.
  • The selected port is currently being used. Restart your computer and try again.
  • The scanner driver is not installed or the operating environment is not setup properly.
  • Ensure that the machine is properly connected and the power is on, then restart your computer.
  • The USB cable may be improperly connected or the power may be off.
Thank you and God bless.
2answers
Lexmark X125
This is very unusal with All-in-one printers. Have you try Hard reset till? Keeping the power on button press for 10 sec till it get on..
Also is the error showing on display screen of printer or at PC? Which Os is running on your PC.
Please also try this --> Power off the printer then computer, Unplug the printer from PC and then main power board--> then restart PC --> after then shut down PC and then again attach printer to PC and power on.
Let me know about the printer spooling if showing any error in Printer setting window.
4answers
k24674
Grand Canyon Tech
Grand Canyon Tech
