The license plate lamps are designed to illuminate the plate and registration tags on your vehicle and make it easily visible to law enforcement. In many states, a burnt out license plate bulb can get you a ticket.
Step 1: Locate the license plate light. The license plate light is located right above the plate.
Step 2: Determine which bulb has failed. Park your vehicle and set the emergency brake. Turn the ignition to the Accessory position and turn on the driving lights. Walk around the vehicle to determine which license plate bulb has failed.
Step 3: Remove the license plate light cover. Remove the license plate light cover retaining screws using a screwdriver.
- Note: You may need to use a small screwdriver to pry the cover off.
Step 4: Remove the bulb. Remove the bulb from its retainer.
Part 2 of 2: Install the bulb
Materials Needed
- Protective gloves
- Replacement license plate light bulb
- Safety glasses
- Screwdriver
Step 1: Install the new bulb. Install the new bulb in its retainer and ensure it is in place.
- Tip: Refer to your car's user manual to determine the correct type of light bulb to get for your specific vehicle.
Step 2: Complete the installation. Put back the license plate light cover and hold it in place.
Install the license plate light cover retaining screws and tighten them using a screwdriver.
Step 3: Check the lights. Turn on your car to check if your license plate lights are fully functional.
