Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
BobLiz Allen Posted on Aug 02, 2015
Control lock light is on..can not cancel. - Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
How do I cancel the control lock
It would help if you gave the brand and model number of your dishwasher, but the answer is basically the same. Look carefully at your dishwasher control panel. You probably have a little lock symbol that is lit up (or a light inside the symbol is lit). And usually this lock symbol is located near (usually above) a button that is usually used for another purpose. Most often this is the Heated-Dry key or button. Press and hold this key for 3 to 5 seconds until the lock symbol light goes out. And it's just that easy! But if you press the key, and nothing happens, then you may have a bad control console that will have to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 25, 2015 • Dishwashers
tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
Kenmore ultra wash D/W wont start. can cancel things but wont start no heat light and lock on light alternates.
Well, I could be wrong, but is sounds like a bad control module or control console (keypad).
2helpful
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
2helpful
2answers
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
3helpful
2answers
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
7helpful
3answers
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
23helpful
5answers
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 • Dishwashers
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
